Can anybody share a working Servo Configuration..
- Piscis
10 Feb 2013 19:00 #29855
by Piscis
Replied by Piscis on topic Can anybody share a working Servo Configuration..
I did all the commenting out steps but LinuxCNC is still complaining, Here is the Debug file information:
dl.dropbox.com/u/58111636/Anibal_LinuxCNC.hal
dl.dropbox.com/u/58111636/Anibal_LinuxCNC.ini
dl.dropbox.com/u/58111636/Linux%20Termin...%20with%20an%20Error
Thanks all.
Thanks all.
- cncbasher
- Thank you received: 288
10 Feb 2013 20:04 #29857
by cncbasher
Replied by cncbasher on topic Can anybody share a working Servo Configuration..
your error is here : Anibal_LinuxCNC.hal:70: Pin 'bldc.0.rawcounts' does not exist
are you using brushless motors ? , this is looking for an input pin which does not exist in your hal file this shows the error as line 70 in your hal file
the pin needs defining before it is used here .
sorry I have not used brushless motors as yet , so perhaps AndyPugh or another moderator can step in and advise further ..
- Thank you received: 5215
11 Feb 2013 00:01 #29865
Replied by PCW on topic Can anybody share a working Servo Configuration..
Look like a pncconf bug or user error with incorrect pncconf options set
(why is the BLDC stuff there at all? certainly makes no sense with a 7I77)
- Piscis
11 Feb 2013 20:13 #29902
by Piscis
11 Feb 2013 22:54 #29912
What driver do you have for the motor?
The BLDC component only make sense with
certain drivers and usually makes no sense if you
are using the 7I77
are using the 7I77
- Piscis
11 Feb 2013 23:20 #29917
by Piscis
12 Feb 2013 00:40 #29922
The BLDC component make no sense for these drives, so the question is why is it there?
- Piscis
12 Feb 2013 02:23 #29924
by Piscis
OK I will comment it out and see if it stops giving me the “LinuxCNC Terminated with an Error” message.
- Thank you received: 4967
13 Feb 2013 02:16 #29971
You may need to go back to PNCConf and get it to create a normal servo config. The bldc component is only needed in cases where the motor commutation happens inside LinuxCNC.That pretty much means only with the Mesa 8i20 and 7i39 drives.
Replied by andypugh on topic Can anybody share a working Servo Configuration..
Just commenting out the line is unlikely to be the full solution.OK I will comment it out and see if it stops giving me the “LinuxCNC Terminated with an Error” message.
- Piscis
16 Feb 2013 21:34 #30187
by Piscis
You were correct, the problem was solved immediately after deselecting "Use Brushless Motor Control" (see screen shots)
THANKS ALL
dl.dropbox.com/u/58111636/Screenshot%231.png
dl.dropbox.com/u/58111636/Screenshot%232.png
THANKS ALL
