virtual button tied to program file
- beltramidave
- Thank you received: 4
28 Feb 2013 03:02 #30658
by beltramidave
virtual button tied to program file was created by beltramidave
Here we go again. A while back I had a project that I needed help with. My customer wanted to create bar codes from their cnc program files and then while in Axis, scan the bar code to open the correct program instead of drilling through a folder looking for them. I was able to make that work..with quite a bit of help.
Now it seems they want to go another route on a different project. When I started this project, they were all for the bar code scanner method. Now after I have pretty much everything ordered, they want to use a touch screen...not just a touch monitor. Right now I don't think a touch screen is going to happen, but I was wondering how difficult it would be to make virtual buttons that would either be on the right side of the Axis screen or under another tab that they could have their program files tied to. I am hoping that if this is relatively painless to accomplish this on my end, then I could also use a touch monitor with Axis to get closer to the solution that they want.
I am to meet with them next week, so if anyone out there has a solution for me, please come forward.
Thank you!
Thank you!
- BigJohnT
- Thank you received: 1175
28 Feb 2013 04:37 #30659
by BigJohnT
Replied by BigJohnT on topic virtual button tied to program file
What's the difference between a touch screen and a touch monitor?
You can add pyvcp buttons and even have tabbed pages on the right of Axis, but Axis is not a good touch screen GUI. There is Touchy a GUI for touch screens and you can add GladeVCP buttons to it. Just depends on what they are looking for. Take a look in the GUI section at some of the touch screen screenshots.
- beltramidave
28 Feb 2013 04:53 #30661
by beltramidave
Replied by beltramidave on topic virtual button tied to program file
I come from a PLC/HMI background where a touch screen is something that requires external software to design your screen images and then is usually connected to a PLC to run industrial equipment. To me a touch monitor is basically a PC monitor with touch capability used with a PC. Hope that make sense.
I have looked in the GUI section and at Touchy. I think I can create a button or even a tabbed page, but I don't have a clue how to make the button open a program file. I was hoping that I could do this from Axis as I didn't want to have to have more external buttons for the operator. This machine is going to do a very simple positioning move. There is no machining involved, just positioning a 2 axis table.
Thanks for your help, I will keep searching the web.
- Thank you received: 1455
28 Feb 2013 05:56 #30663
Replied by Todd Zuercher on topic virtual button tied to program file
It is very easy to create a button that calls and runs one program. I have several that run useful sub programs for me, Such as one that I call "Clear" that turns off the routers, raises the heads and returns the machine to the home ready position. Is this the sort of thing you need?
- cradek
- Thank you received: 9
28 Feb 2013 05:57 #30664
by cradek
Replied by cradek on topic virtual button tied to program file
Touchy already has the list of programs that are "in the control" on the Auto tab. You just touch the one you want, it loads instantly, and then you poke your cycle start button to run it. Isn't that already what you want?
- beltramidave
28 Feb 2013 06:05 - 28 Feb 2013 11:33 #30665
by beltramidave
Todd,
Yes, that is what I want. I want to create as many buttons as I need and tie them to the various programs that I will create to run this table instead of drilling down through a list of programs in a folder somewhere.
Can you give me details on how to do this?
Thank you.
Thank you.
Last edit: 28 Feb 2013 11:33 by beltramidave.
- beltramidave
28 Feb 2013 06:07 #30666
by beltramidave
I was hoping to use Axis to do this, but can look into Touchy more. How do you get the programs "in the control" to select from?
- cradek
28 Feb 2013 08:54 #30667
by cradek
AXIS works pretty poorly on a touch screen; its strength is its keyboardability. Touchy is much better.
To "load" the files you just stick them in the linuxcnc/nc_files directory. I use a network connection for adding and deleting files.
- beltramidave
28 Feb 2013 11:38 #30669
by beltramidave
Cradek,
I looked at Touchy and you are correct, that it is very easy to get what I am after there. How hard is it to modify the Touchy screens? My machine is only a 2 axis positioning table and this interface is kind of over whelming for my needs.
Is the reason that Axis doesn't work well with a touch screen because of the size of the icons or what? I would really like to hear how Todd creates the buttons that he uses.
Thanks for your help.
- BigJohnT
28 Feb 2013 20:54 - 28 Feb 2013 20:56 #30677
by BigJohnT
Yes that makes perfect sense to me. I too have been working with PLC's and touch screens for a long time but never thought of them in this context.
You might look at just making your own GUI for a simple position table. I have some GUI tutorials that might help you understand how to do that.
I've used Axis with a touch screen and yes the size of the buttons and tabs makes that a challenge.
Are the files simply a single line position move or something like that? In that case you could use MDI commands connected to each button with halui.
Last edit: 28 Feb 2013 20:56 by BigJohnT.
Time to create page: 0.063 seconds
