virtual button tied to program file
- beltramidave
- Thank you received: 4
28 Feb 2013 21:07 #30679
by beltramidave
Replied by beltramidave on topic virtual button tied to program file
Thanks John, I never even thought of making my own GUI. I have seen some of your tutorials and I might look into that further. I don't understand all the programming very good that goes into making things happen.
I actually have not created any files yet, but yes, they should just be a very simple G0 X_Y_. The machine will need to be homed first.
- BigJohnT
- Thank you received: 1176
28 Feb 2013 21:44 #30680
by BigJohnT
Replied by BigJohnT on topic virtual button tied to program file
As an example this is how I created a rapid to home position for my plasma machine. So for each position create a button, the MDI command, and the link in the hal file. If you don't have halui loaded then you can
add it via the ini file
To get the Rapid to Home button you need to add a line in your ini file in the [HALUI] section:
MDI_COMMAND = G0 X0 Y0 Z0
and in your pyvcp xml file add this
<labelframe text="MDI Commands">
<button>
<halpin>"rapid-to-home"</halpin>
<text>"Rapid to Home"</text>
<font>('Helvetica',10)</font>
</button>
</labelframe>
and in your postgui.hal file add this
# MDI commands
# rapid to home button
net remote-rapid-home halui.mdi-command-00 <= pyvcp.rapid-to-home
<button>
</button>
</labelframe>
# MDI commands
The following user(s) said Thank You: beltramidave
- beltramidave
28 Feb 2013 21:58 #30681
by beltramidave
Thanks again John! You have no idea how much this helps.
- beltramidave
01 Mar 2013 00:20 #30690
by beltramidave
John,
Are the Axis and Touchy config files available somewhere, so that instead of re-creating everything, one could maybe do some copy and pasting to create their own GUI?
- BigJohnT
01 Mar 2013 05:35 - 01 Mar 2013 05:36 #30698
by BigJohnT
All the files are in the
Git repository
y.
Axis is so complicated and confusing good luck with even trying to find where everything is... the simplest thing is to add a pyvcp panel to Axis and add your buttons there. I have some GUI tutorials that cover some things...
Last edit: 01 Mar 2013 05:36 by BigJohnT.
- Thank you received: 1467
23 Mar 2013 00:47 #31736
Replied by Todd Zuercher on topic virtual button tied to program file
If you wanted a file to move to the machine origin and call it from a pyvcp button you would set up your button just like John said then, if you call the file "origin" the file would be
oorigin sub
g90
g0g53z0
g0g53x0y0
oorigin endsub
Then you would make your halui command in your ini file be
MDI_COMMAND = oorigin call
The sub file does not have to have the ngc file extension. (mine don't) But I don't think it matters if they do. These subroutine files need to be saved to the directory pointed to by PROGRAM_PREFIX in your ini file.
oorigin sub
g90
g0g53z0
g0g53x0y0
oorigin endsub
- beltramidave
23 Mar 2013 00:56 #31737
by beltramidave
Thanks for your help, Todd. That worked perfectly...other than I believe that I will be limited to only 64 MDI calls as I believe that is the max. If there is another method, I would be interested in that. 64 may be enough...but then it may not be either.
Thanks again
Thanks again
- ArcEye
- Thank you received: 758
23 Mar 2013 23:04 - 23 Mar 2013 23:20 #31767
by ArcEye
You are limited to 64 halui MDI commands, because that is hard coded in the .ini parsing routine
However you can pass parameters to subroutine calls, so you can have infinite(ish) next level subroutines, which one is executed being determined by the value passed as a parameter.
eg
syntax o <origin> call N where N is the value to pass as param
(local param #1 is the first parameter passed to the subroutine)
You would have to do things differently to your current setup, but the principle works from code or halui mdi commands, it's just a question of how you pass the value
Replied by ArcEye on topic virtual button tied to program file
....I believe that I will be limited to only 64 MDI calls as I believe that is the max. If there is another method, I would be interested in that. 64 may be enough...but then it may not be either.
eg
o <origin> sub
if[#1 EQ 0]
; do stuff
else if[#1 EQ 1]
; do other stuff etc. etc.
endif
o <origin> endsub
Last edit: 23 Mar 2013 23:20 by ArcEye.
Time to create page: 0.131 seconds
