Nema 23. Slow
  • MakingToothpicks
  • Senior Member
  • Senior Member
13 May 2013 01:30 - 13 May 2013 01:32 #33966 by MakingToothpicks
Replied by MakingToothpicks on topic Nema 23. Slow
i'm guessing you may have a faulty stepper driver ..especialy as the voltages you have measured are different on the z and you say the motor is hot
although it is quite normal for steppers to be quite warm to touch and give the impression of a fault , remember stepper motors are energised also at the stationary point , hence why they run hot
are all your motors the same ? i.e the wiring is identical between them all ? i'll presume they are .
try swapping the stepper motor wiring from the z to say drive x and see if the motor runs ok . if yes then I would say the z stepper driver is faulty
check the dip switch settings for the z axis and make sure they are correct ..
This one was to hot to touch. You would burn your hand.
All motors are wired the same Black , Yellow , Red , White. All 4 motors are also the same model.
Motor runs when plugged into another axis.
Last edit: 13 May 2013 01:32 by MakingToothpicks.
  • MakingToothpicks
  • Senior Member
  • Senior Member
14 May 2013 21:31 #34083 by MakingToothpicks
I have decided that the controller card is bad. So I am getting a new one.
I ordered another TB6560 blue one from E-Bay. It will be a couple of weeks
until it arrives . With some new hospital and doctor bills needing my
attention I had to go this route.
I will post again when I get the card.
Thank You
  • MakingToothpicks
  • Senior Member
  • Senior Member
18 May 2013 01:55 #34264 by MakingToothpicks
Can someone explain how to connect Black Yellow Green together and the Red White and Blue.
the way they show in the attached PDF file. connecting the 3 wires is supposed to give better speed.
I have seen others that show wiring the 3. They do not really show what gets connected to what. I am
using the TB6560 blue controller board.
Thank You
19 May 2013 07:03 #34364 by andypugh
Replied by andypugh on topic Nema 23. Slow
No, because that diagram makes no sense at all.
The words describe series/parallel connection of 8-wire motors. The picture is showing bipolar and unipolar wiring (well, sort-of) with 6-wire motors.
You _could_ wire the centre tap into the driver _instead_ of one of the phase wires. This would give you about half the torque and about twice the speed. I don't think anyone does.
20 May 2013 11:05 #34415 by jaredts
Replied by jaredts on topic Nema 23. Slow
Using all six wires like the diagram on the left is only for a unipolar stepper driver. Since you have a bipolar driver you have the option to wire it like the diagram on the right, which does give you the highest holding torque and very low speed torque. If you instead use one of the center taps and one of the other phase wires for each phase then you have wired the motor half coil. Although there is a small penalty in holding torque and low speed torque, you will get much more speed and have much more torque available at anything but a crawl. Google the subject and read up on it--you'll probably decide that you need to use half winding. Or try it both ways and see for yourself. You need to set your stepper driver max. current appropriately for each of the two wiring options.
  • MakingToothpicks
  • Senior Member
  • Senior Member
25 May 2013 03:27 #34655 by MakingToothpicks
I have been working on the machine. I have been keeping up with all replies.
I did receive the new controller card and all 3 axis are working.I will be doing some testing
tonight or tomorrow. I will keep everyone informed. I am sure I will have some more questions.
I will now need to get to the nuts and bolts on how to cut things. Any suggestions for reading
that is easy and simple. Just some basics to get going.
Thank all of you for the help so far. It has been great.
Don
25 May 2013 14:45 #34669 by Rick G
Replied by Rick G on topic Nema 23. Slow
Glad to hear you are getting it sorted out.
You might look here...
www.sherline.com/CNClinks.htm
Rick G
13 Nov 2013 06:23 #40774 by fannlow
Replied by fannlow on topic Nema 23. Slow
I just saw this topic and decided to also drop in for some help :laugh:
As I have previously posted, my motors are running very slow but stable...
slow, I mean somewhere around 10~20mm/sec...
however, when I turned up the velocity say from 10mm/s to 11mm/s...
it will start to vibrate, or just sounds of vibrationg and not moving at all..
then it comes a high pitched, frequency sound...
and i have to hit cancel on LinuxCNC
tried these with the 3 driver boards that came, and also with 3 different motors...
cross-connecting them as I go, so I have tried the same and are true for all 9 so times, as I switched...
I am unsure if this is due to not enough "ground"?
because I am using the controller board GND, which came from the USB-to-PC, and then splicing them to all the 3-driverboards...
I'm unsure if I can just send these GND from driver boards into a big piece of metal?
say... the framework of the CNC? since I made it using metal?
any help here would be very much appreciated...
•3 pcs Nema 23 stepper motor with 425 oz.in,3A
•3 pcs Stepper motor driver DM542A, 24-50VDC, 128 MICSTEPS
•1 pc 350W-36V power supply
its running on half-step, if i remember correctly...
here's the link I posted once, with the settings I'm using...
www.linuxcnc.org/index.php/english/forum...42-step-timespacedir
thanks =)
13 Nov 2013 07:42 #40775 by BigJohnT
Replied by BigJohnT on topic Nema 23. Slow
It is always better to start a new topic...
JT
13 Nov 2013 08:21 #40776 by fannlow
rgr tht
