I need linuxcnc on 12.04lts ?
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
25 May 2013 00:27 #34649 by RobotMatic
I need linuxcnc on 12.04lts ? was created by RobotMatic
My moher doesn't work with 10.4 lts The error from CD live is
(initramfs) unable to find a medium containing a live file system
The versions 12.04 LTS and 13.04 work properly.
How can I solve the problem if Linux CNC only works with 10.04 LTS?
My mother is Asus P8 H61-M LX with processor Intel G630 2,7 GHz, 3 MB Cache.
I look forward to your helpful answer.
Thanks in advance.
Eduardo
25 May 2013 20:23 #34678 by ArcEye
Replied by ArcEye on topic I need linuxcnc on 12.04lts ?
Hi
First of all check that SATA is in AHCI mode in BIOS
The error you are getting is nothing to do with Linuxcnc, it is the LiveCD isolinux booter not being able to find your drives.
If it still does not work you are left with this
wiki.linuxcnc.org/cgi-bin/wiki.pl?XenomaiKernelPackages
which does work with 12.04
The following user(s) said Thank You: RobotMatic
27 May 2013 00:11 #34723 by Rick G
Replied by Rick G on topic I need linuxcnc on 12.04lts ?
Have you tried burning a second CD? Have you checked the MD5SUM of the CD?
Rick G
  • RobotMatic
  • Elite Member
  • Elite Member
31 May 2013 18:19 #35009 by RobotMatic
Replied by RobotMatic on topic I need linuxcnc on 12.04lts ?
Thanks for the reply. But I am don't have solution.
01 Jun 2013 09:44 #35072 by andypugh
Replied by andypugh on topic I need linuxcnc on 12.04lts ?
I think it is possible to run LinuxCNC on 12.04, but it is a fair bit of work at the moment. How good are you at Linux and compiling custom kernels?
(Yes, I know it shouldn't be this hard, it is due to a situation outside the control of the LinuxCNC project).
We are very close to having a system that will run on _any_ current Linux distribution, but not quite there.
There are ways, but you need to be better at Linux than me to use them (not that hard)
  • RobotMatic
  • Elite Member
  • Elite Member
06 Jun 2013 05:11 #35297 by RobotMatic
thanks. !!!
I have 5 mother in this situation!!. linuxcnc 2.6 work in 12.04 lts ?. I buy old mother for work with linuxcnc !!!!!
06 Jun 2013 06:31 #35302 by andypugh
  • RobotMatic
  • Elite Member
  • Elite Member
07 Jun 2013 02:37 #35364 by RobotMatic
thanks andypugh !!!!, but I need work with the machine on linuxcnc. Your solution is not good for work.
The new 2.6 work in 12.04 LTS ?
regards !!!
07 Jun 2013 03:18 #35367 by andypugh
I am not sure what you mean. That process should give you a perfectly functional LinuxCNC installation.
07 Jun 2013 03:23 #35368 by mhaberler
Replied by mhaberler on topic I need linuxcnc on 12.04lts ?
regards !!!
Edugonza,
while I dont exactly understand what your plans are I am fairly sure that there is no point in trying alternative installation methods, which are more complex, if you cant get a liveCD to work
switch to a different PC and try again - the liveCD works fine, I am rather sure this is a problem with your setup
- Michael
Time to create page: 0.075 seconds
