I need linuxcnc on 12.04lts ?
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
08 Jun 2013 00:04 #35418 by RobotMatic
Replied by RobotMatic on topic I need linuxcnc on 12.04lts ?
To make it clearer, with the mother ASUS P8 H 61-M LX Rev 3.0 any of the 10.04 LTS (with or without Linux CNC) work.
The error is what I mentioned in my first post.
On the other hand, 12.04 LTS and 13.04 install properly but I need Linuxcnc.
We make RobotMatic CNC equipment ( robotmatic.blogspot.com) in Argentina. We have 5 new mothers with this problem for 5 new RobotMatic.
So far, the only solution we have is using old mothers.
Will Linux 2.6 work with 12.04 LTS????
Regards,
Eduardo
08 Jun 2013 00:23 #35419 by BigJohnT
Replied by BigJohnT on topic I need linuxcnc on 12.04lts ?
There is no LinuxCNC 2.6. The latest released version is 2.5.2. There are several experimental branches and the branch Master is often mistaken for 2.6 with does not exist.
JT
08 Jun 2013 00:27 #35420 by mhaberler
Replied by mhaberler on topic I need linuxcnc on 12.04lts ?
Regards,
Eduardo
It will work perfectly fine, assuming you get the Xenomai 3.5.7 kernel up and running ok
Once you have 12.04 up, follow these steps: wiki.linuxcnc.org/cgi-bin/wiki.pl?XenomaiKernelPackages
Please report if you can get that to work; we very likely be of limited help if this board doesnt work/work well with that kernel
Once that works, you can build off this branch: git.mah.priv.at/gitweb?p=emc2-dev.git;a=...heads/rtos-master-v0
this branch isnt announced yet, but it has been reported to work fine and is uptodate wrt master and v2.5_branch as of yesterday
alternatively you can try Debian wheezy and the rt kernel which is stock in debian; this should work too
IMO there is no reason to be fixated on Ubuntu anymore, and much of the stuff in 12.04 is more of a legacy than a help
- Michael
08 Jun 2013 00:33 #35421 by BigJohnT
What if anything do you have to do after installing Debian Wheezy to get the rt kernel?
JT
08 Jun 2013 00:43 - 08 Jun 2013 00:48 #35423 by mhaberler
the current wheezy RT-PREEMPT kernels are tagged linux-image-3.2.0-4-rt*
image should do; kernel headers are not required for the abovementioned branch
from there on its all stock: boot that kernel
pull that branch, and as usual:
cd src
sh autogen.sh
./configure
make
sudo make setuid
latency will very likely be a bit worse than the xenomai kernel
- Michael
Last edit: 08 Jun 2013 00:48 by mhaberler. Reason: typo
12 Jun 2013 04:13 #35551 by tld70
Replied by tld70 on topic I need linuxcnc on 12.04lts ?
Hello Guys
it it possilbe to get a step by step description in german to install
a real time kernel an linux cnc 2.6 for dummies?
I only get errors.....
or is this to early?
is there a plan to get a iso like the 10 04
Thomas
  • RobotMatic
  • Elite Member
  • Elite Member
15 Jun 2013 00:10 #35641 by RobotMatic
Thanks Michael!
I'm trying everything you suggested. I'll follow the instructions step by step although I'm not expert at Linux but I have many many hours on Linuxcnc.
In my humble opinion 10.04 version is old fashioned and I feel that the project Linuxcnc should have migrated to a much more modern Linux.
I know and I respect that it's hard work. I appreciate your effort.
Thanks and regards,
Eduardo
17 Jun 2013 13:01 #35732 by 3kamalakkannan
Replied by 3kamalakkannan on topic I need linuxcnc on 12.04lts ?
Hi Friend,
ubuntu-10.04-linuxcnc3-i386.iso Supports in AHCI mode.
Step1: Goto BIOS Settings
Step2: SATA Configuration
Step3:Change SATA mode to AHCI Mode
Step4:Save and Exit
Now you can install in SATA hard drives
The following user(s) said Thank You: RobotMatic
17 Jun 2013 14:47 #35735 by ArcEye
Replied by ArcEye on topic I need linuxcnc on 12.04lts ?
Hopefully he has already tried that, as it was the first thing that I advised
ArcEye wrote:
First of all check that SATA is in AHCI mode in BIOS
But maybe not :unsure:
  • RobotMatic
  • Elite Member
  • Elite Member
18 Jun 2013 07:26 #35765 by RobotMatic
Thanks ArcEye and 3kamalakkannan for your replies.
Today I finally installed Ubuntu 10.4 in the mothers.
The solution was setting SATA as AHCI mode and jumping the harddisc as master.
So far that's all.
Thanks again.
Regards
Eduardo
The following user(s) said Thank You: jlviloria
