2.6.0 problem with the tool table editor
- garymcrobertpdx
25 May 2013 01:42 #34651
by garymcrobertpdx
2.6.0 problem with the tool table editor was created by garymcrobertpdx
LinuxCNC version 2.6.0 seems to have a problem with failing to open the tool table editor
although this is not a show stopper it is a significant inconvenience. Is there an easy fix?
- RobotMatic
- Thank you received: 22
25 May 2013 03:01 #34654
by RobotMatic
Replied by RobotMatic on topic 2.6.0 problem with the tool table editor
where is linuxcnc 2.6 ?
- Thank you received: 2159
25 May 2013 07:30 #34656
Replied by cmorley on topic 2.6.0 problem with the tool table editor
Since there are multiple GUIs and multiple tooltables, could you be more specific please?
- BigJohnT
- Thank you received: 1176
25 May 2013 18:44 #34674
by BigJohnT
He is mistakenly calling master 2.6, there is no 2.6.
JT
Replied by BigJohnT on topic 2.6.0 problem with the tool table editor
JT
- Thank you received: 1464
25 May 2013 19:55 #34677
Replied by Todd Zuercher on topic 2.6.0 problem with the tool table editor
Well the splash screen when opening master does say 2.6...
25 May 2013 23:06 #34686
Well your both right.
As developers we consider 2.6 as the next release, which hasn't happened yet.
We refer to releases by number and development by name (master)
but 2.6 and master are the same thing right now.
If your not a developer you wouldn't know that and would refer to it as it displays it. Too bad we can't get it to say master-2.6
I might add that it would be nice to know if there is an error message (you might try running linuxcnc from a terminal to see extra messages)
and a post of your INI file would be handy too.
Chris M
Chris M
- garymcrobertpdx
25 May 2013 23:27 #34688
by garymcrobertpdx
Replied by garymcrobertpdx on topic 2.6.0 problem with the tool table editor
OK here is a copy of the ini. How do I launch the machine from a terminal?
# Generated by PNCconf at Thu May 23 17:44:30 2013
# overwritten when you run PNCconf again
[EMC]
MACHINE = my_LinuxCNC_machine
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.250000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/me/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.8333
MAX_LINEAR_VELOCITY = 1.67
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 6.00000
MAX_ANGULAR_VELOCITY = 12.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyzab
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[PYTHON]
# where to find Python code
# code specific for this configuration
PATH_PREPEND=./python
# generic support code
PATH_APPEND=/home/me/linuxcnc/python
# import the following Python module
TOPLEVEL=/home/me/linuxcnc/python/toplevel.py
# the higher the more verbose tracing of the Python plugin
LOG_LEVEL = 0
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = my_LinuxCNC_machine.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 5
COORDINATES = X Y Z A B
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 60.00
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.5
MAX_LINEAR_VELOCITY = 1.0
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.5
MAX_ACCELERATION = 3.0
# these are in nanoseconds
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = -20000.0
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 5.000000
HOME_SEARCH_VEL = 1.000000
HOME_LATCH_VEL = 0.100000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.5
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 20000.0
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 3.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.5
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Axis A
[AXIS_3]
TYPE = ANGULAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 360.0
MAX_ACCELERATION = 300.0
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 40.0
MIN_LIMIT = -360.0
MAX_LIMIT = 360.0
HOME_SEARCH_VEL = 0.000000
HOME_LATCH_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Axis B
[AXIS_4]
TYPE = ANGULAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 120.0
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = -40.0
MIN_LIMIT = -100.0
MAX_LIMIT = 10.0
HOME_OFFSET = 4.150
HOME_SEARCH_VEL = 1.500000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
MAX_VELOCITY = 36.6666666667
MAX_ACCELERATION = 30.0
ENCODER_SCALE = 400.0
DIRSETUP = 200000
DIRHOLD = 2000
STEPLEN = 2000
STEPSPACE = 2000
STEP_SCALE = -1000.0
[EMC]
DEBUG = 0
[DISPLAY]
DISPLAY = axis
INTRO_TIME = 5
EDITOR = gedit
GEOMETRY = xyzab
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[PYTHON]
LOG_LEVEL = 0
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HOSTMOT2]
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
[HALUI]
[TRAJ]
AXES = 5
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.5
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.5
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.5
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Axis A
[AXIS_3]
TYPE = ANGULAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 40.0
MIN_LIMIT = -360.0
MAX_LIMIT = 360.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Axis B
[AXIS_4]
TYPE = ANGULAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
DIRSETUP = 200000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = -40.0
MIN_LIMIT = -100.0
MAX_LIMIT = 10.0
HOME_OFFSET = 4.150
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
DIRSETUP = 200000
DIRHOLD = 2000
STEPLEN = 2000
STEPSPACE = 2000
- BigJohnT
25 May 2013 23:28 #34689
by BigJohnT
Actually 2.6 could come from 2.5 and not master, so yes it should just say what every branch it really is like master, ja3 etc to avoid confusion. You can see from the current list of branches there is no 2.6 branch.
JT
master
v2.5_branch
manpage-src
rtapi-bitops-gcc-intrinsics
rtos-integration-preview3
jepler/rtapi-more-headers
joints_axes3
rtos-integration-preview3-merged-into-master
master-coolant
dynload-rtapi
x86_64buildflags
hardy-workaround
jepler-modlinking
2.5.1-halui-probe-mdi
master-halui-jog-bug
master-with-redis
JT
- BigJohnT
25 May 2013 23:32 #34690
by BigJohnT
For a RIP of master assuming you have ran make and ran sudo make setuid
then pick your config from the configuration selector.
JT
cd (name of rip directory)
. ./scripts/rip-environment
linuxcnc
JT
- garymcrobertpdx
26 May 2013 01:03 #34693
by garymcrobertpdx
It appears that the problem was with the tool table! For some reason the tool table contained
some kind of error. When I replaced the tool table with one from my old 2.5 linuxcnc it the editor
started working.
started working.
