2.6.0 problem with the tool table editor
- garymcrobertpdx
08 Jun 2013 03:13 #35426
by garymcrobertpdx
Replied by garymcrobertpdx on topic 2.6.0 problem with the tool table editor
Well once again I spoke to soon. It appears that there is some sort of problem with the tool table editor.
Some times it works and but most often it fails to open. A bit of a pain in the neck
- Thank you received: 4966
17 Dec 2013 06:14 #41659
There is a problem there. I keep meaning to isolate it, and raise a bug tracker.
A workaround is to launch the tool editor from the command line. You could even add it to the CNC menu.
the command is "tooledit"
Replied by andypugh on topic 2.6.0 problem with the tool table editor
- BigJohnT
- Thank you received: 1176
17 Dec 2013 07:50 #41663
by BigJohnT
Replied by BigJohnT on topic 2.6.0 problem with the tool table editor
Just so you know the 2.6 branch has not been created yet, so your most likely working with master. I would make it easier to trouble shoot if you used the correct branch name.
JT
JT
Time to create page: 0.057 seconds
