No movement?
- Rick G
- Thank you received: 155
19 Jun 2013 18:20 - 19 Jun 2013 18:21 #35812
by Rick G
Replied by Rick G on topic No movement?
It is the max jitters you need to look at. Your results are bad.
Take a look at the earlier post to this topic for latency and how to troubleshoot and correct it.
Rick G
Rick G
Last edit: 19 Jun 2013 18:21 by Rick G.
- Rick G
20 Jun 2013 17:11 #35835
by Rick G
Your first post stated you were using 10.04, have you tried 8.04 also? If not you can run the latency test right from the 8.04 CD without installing.
Rick G
Rick G
- JayDeeTOL
21 Jun 2013 00:11 #35843
by JayDeeTOL
Replied by JayDeeTOL on topic No movement?
Thanks Rick. Everything is working fine except that first message i get when I start the program. Just turning wood dowel rods for now cause wood is cheap. I've tried re-setting some of the bios setting but that was no good either. I'm getting gCode pretty fast, Now I'm looking into getting a stand alone controller or a new computer. The parts I'm making aren't that sophisticated I would just like precision every time.
Time to create page: 0.052 seconds
