Password problem
04 May 2014 07:16 #46565 by phillc54
Replied by phillc54 on topic Password problem
Space is missing after the add command.
The following user(s) said Thank You: allenwg2005
04 May 2014 13:50 #46572 by ArcEye
Replied by ArcEye on topic Password problem
As he says, that is why that command did not work.
You seem to be having a lot of problems which could be solved by simply cutting and pasting.
Highlight the command on the web page or document and Ctrl C, then go to the command line and Shift Insert
The instructions just need following, just remember to do apt-get update after adding the new repo or its contents will not be found
  • allenwg2005
  • allenwg2005's Avatar Topic Author
  • Elite Member
  • Elite Member
05 May 2014 02:40 #46590 by allenwg2005
Replied by allenwg2005 on topic Password problem
Here is the strange thing; I am cutting and pasting.
I don't have enough faith in my typing/syntax skills to do this any other way.
I assumed the space after the “add command" would be a spaces at the end of the following command line “System-->Administration-->Software Sources-->Third-party software-->Add “, if I have understood your directions correctly, I tried this and got the same results as before.
Am I misinterpreting your help?
I agree, this should be as simple as follow the directions, do a little cut & paste, and you're done.
It's just that I apparently can't do something as straight forward as that.
Talk about feeling like an idiot!
Where am I going wrong here?
05 May 2014 06:41 #46595 by phillc54
In your previous screenshot there was no space between add & /
sudo apt-key add /tmp/webersys-key.gpg
  • allenwg2005
  • Elite Member
  • Elite Member
05 May 2014 22:51 #46633 by allenwg2005
So what has happened here?
daliel@daliel-desktop:~$ wget -q webersys.poweb.com -O /tmp/webersys-key.gpg
daliel@daliel-desktop:~$ sudo apt-key add /tmp/webersys-key.gpg
[sudo] password for daliel:
gpg: no valid OpenPGP data found.
Time to create page: 0.065 seconds
