Linuxcnc servo spindle encoder with pulleys
- Thank you received: 4968
02 Sep 2014 00:22 - 02 Sep 2014 00:23 #50591
Replied by andypugh on topic Linuxcnc servo spindle encoder with pulleys
It isn't impossible to make your own timing pulleys. I needed a very strange cup-shaped one for my X axis drive and made it myself.
For the round-tooth style belts you can drill a circle of holes then machine off the outer half.
I did it the hard way, setting my milling machine up as a hobber and buying a T5 hob from eBay.
In theory I could cut teeth on a blank you provided, but in practice transatlantic postage probably makes that impractical.
Last edit: 02 Sep 2014 00:23 by andypugh.
- nilrods
03 Sep 2014 01:00 #50641
by nilrods
Replied by nilrods on topic Linuxcnc servo spindle encoder with pulleys
Andy,
Thanks, but your probably right on the trans-Atlantic shipping
I had seen one of your previous videos. It looked great!
I was actually planning to doing something similar in the future with a small old Atlas Horizontal mill(you might have just given me the push I needed to prioritize that). I had looked at some of the linuxcnc pages around that.
I assume you just use a decent number encoder on your spindle(something like 1024 or just more than just an index pulse). How to you gear the spindle to the rotary table? Do you just use some arc length function in Linuxcnc (like L=(pi*r*angle)/180) then apply by the number of teeth or something?
Thanks,
Chris
Thanks,
Chris
03 Sep 2014 01:03 #50643
The horizontal miller actually uses a resolver on the spindle, but I set up a vertical miller version using a home-made 25-slot disc and it worked fine.
Some details of the HAL setup are here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Hobbing
The following user(s) said Thank You: nilrods
- Zahnrad Kopf
- Thank you received: 3
03 Sep 2014 06:47 #50656
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Linuxcnc servo spindle encoder with pulleys
Chris if I don't have the Hob you require you could purchase one, send me the Hob with a blank and I could Hob them for you if it comes to it.
03 Sep 2014 15:55 #50671
This eBay store has quite a collection of toothed-belt hobs:
stores.ebay.co.uk/THE-TOOL-AND-TREASURE-...earch&_sid=384582008
(They are all described as gear hobs, but none of them are)
- Zahnrad Kopf
03 Sep 2014 17:55 #50677
by Zahnrad Kopf
That is a dilemma! They are very nicely priced, but lacking VERY important information. So, unless the buyer does some serious research, they're almost useless.
Timing belt Hobs usually come in ranges. 1 - 35 teeth, 36 - 58 teeth, etc... ( strictly as an example ) That's gambling at its finest!
- Zahnrad Kopf
10 Sep 2014 06:44 - 10 Sep 2014 06:45 #50990
by Zahnrad Kopf
Back on the original topic, this fell into my lap today and I'm trying to find out if it might be a suitable replacement for our spindle encoders but cannot find any good information on it yet so do not know if it has an index pulse or not. It _DID_ come from a spindle with an orient function.
The only thing I can find is this - LINK HERE
Last edit: 10 Sep 2014 06:45 by Zahnrad Kopf.
10 Sep 2014 15:15 #50997
You might be able to work something out from here:
www.heidenhain.de/de_EN/php/documentatio...w/file-0034/file.pdf
Especially page 73
Especially page 73
- Zahnrad Kopf
10 Sep 2014 17:21 #51009
by Zahnrad Kopf
Thank you,Andy.
Unfortunately, when I looked at that it appears that someone regurgitated a bunch a symbols and letters into a bag and then emptied the bag. But I stared at it while I drank my coffee and I _think_ it means that there _is_ an index pulse in there. Correct?
Especially page 73
Thank you,Andy.
10 Sep 2014 18:49 #51017
It looks like 3 pairs of data channels, yes, so one ought to be an index.
Unless it is a commutation encoder, but then it wouldn't be marked as "incremental"
Time to create page: 0.080 seconds
