Linuxcnc servo spindle encoder with pulleys
- Zahnrad Kopf
- Thank you received: 3
10 Sep 2014 19:01 #51018
by Zahnrad Kopf
So, this would be suitable to use for the purposes of rigid tapping along with Spindle speed and single point threading, then? ( per the previous discussions )
Replied by Zahnrad Kopf on topic Linuxcnc servo spindle encoder with pulleys
It looks like 3 pairs of data channels, yes, so one ought to be an index.
Unless it is a commutation encoder, but then it wouldn't be marked as "incremental"
- alan_3301
- Thank you received: 33
10 Sep 2014 19:54 #51026
by alan_3301
Replied by alan_3301 on topic Linuxcnc servo spindle encoder with pulleys
- Zahnrad Kopf
21 Sep 2014 22:02 #51408
by Zahnrad Kopf
Thanks Alan. I will likely swap this out with the existing one before things get buttoned up.
Time to create page: 0.063 seconds
