To upgrade or not
- allenwg2005
- Thank you received: 4
2.6 spooks me at this point.
- Thank you received: 5291
Not sure what you think is the issue with 2.6.4, there are many bug fixes between
2.5.4 and 2.6.4 and very little that should affect compatibility.
- allenwg2005
Do I have to burn a live DVD to install 2.6, or can it be upgraded via the internet?
I think I read a while back you have to use the disk.
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.6
- pws
Since release 2.6 was now out there and, I updated my system accordingly, and the problems began!!
What distro do you have installed, as opposed to Linuxcnc version?
EDIT:
To expand on my previous comment.
There is a realtime latency test in /usr/realtime/testsuite/user/latency/run
If you ran it now for a few minutes, then deleted all of linuxcnc and ran it again, I would expect the same readings.
Latency results are governed by hardware, the kernel and realtime but the rt software should not come into it, as it is not even running when the latency test is conducted.
Well, based on some of the responses I got, it was clear to me that I needed to back up and get a handle on what I had in place and understand what's new / improved / changed. I spent quite a bit of time yesterday doing some reading and reorganizing my thoughts!
First, I downloaded the newest (2.6.4) iso and reinstalled from scratch.
Next, I worked through the various posts and the hxc-hb04 "Readme" and now have that working. Thanks for all the input on that (particularly bernie_nor for emphasizing the Readme was key)!
The jitter issue, however, is still not good!
I have notes from a year ago when I first built this new system and it was running 2.5:
Servo: 12951
Base: 6145
No Hardware has been changed.
With the new install from the latest 2.6.4 CD:
Servo: 1874002
Base: 127300
I have no idea why this would change so dramatically and I would appreciate any insight or suggestions on what I might do to improve this.
Thanks!
- ArcEye
- Thank you received: 758
Servo: 1874002
Base: 127300
You need to appreciate that you have NOT 'upgraded to 2.6.4'
You have installed a completely new distro, Debian Wheezy, with a new rtai kernel and a new version realtime.
It has linuxcnc 2.6.4 bundled with it, but that is incidental, it would return the same figures on latency no matter which version you ran.
The older the hardware, the more likely the new distro will not suit.
If you want to return to the lower figures you enjoyed, reinstall what you had before
and upgrade linuxcnc to 2.6.4 as per the instructions
- pws
Hi
Servo: 1874002
Base: 127300
So, what I am hearing is the new distro is "broken" causing the high figures. That's pretty sad!
Once again, the Hardware is NEW.
I will look into re-installing the "OLD" distro and updating that. Seems counter intuitive, but it sounds like that is the only option here.
I see comments such as (PCW - you do not need to re-install linux, assuming you are running ubuntu 10.04 or newer) - which imply that there is a way to run LinuxCNC under the newer versions. Is that something that is published or is is all "sandbox"?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...ck_dmesg_for_details
Your huge latencies suggest that something like power management is enabled.
What Motherboard is this? (someone else may have experience with the same hardware)
- ArcEye
That is not what anyone is saying.
It is not compatible with your system (whatever it is, you haven't said beyond AMD), either at all or as it is currently configured.
That is irrelevant, it either works well with the 3.4.9 kernel and rtai or it doesn't
If your previous installation worked (don't know what that was either, you didn't say) all you had to do was update the CNC software part ie Linuxcnc, to the desired 2.6.
I would try checking all the BIOS options etc first as PCW suggests. If you haven't done something like add a nvidia GPU card or the like since you tested the 'old system',
the difference in figures is so huge there has to be a discernible reason.
- pws
Before going back to a 10.04 installation you might check that _ALL_ power management options are disabled in the BIOs:
ASUS F2A85V Pro FM2
AMD A10-5800K
GSkill 16GB
WD Velociraptor 300G
Mesa 6i25
No changes to BIOS were made since original build. I will check again to verify the Power Management settings.
