Losing My Way
28 Jan 2015 08:39 - 28 Jan 2015 08:54 #55403 by jorsborn
Losing My Way was created by jorsborn
I am looking for suggestions on a problem I am having. I have a large 4'x8' gantry with two motors on the Y axis. All motors are stepper driven using G540 connected to the parallel port. I was having significant issues with the gantry racking so I've tried a bunch of things to try and nail down the source of the problem.
- I've examined the linkages on the two motors. Set screws are tight and there is no play in either.
- I've swapped drivers. What I mean by this is I have taken two other drivers (of the 4 in the G540) and substituted them in to see if it was a driver issue.
- I've changed out the external LPT card for an onboard card.
- I've changed the motherboard.
- I've changed the LPT cable so that one set of step/direction pins are now the input to both drivers. I also had to swap a phase on one of the motors to make this work.
- I've tried running at very low speeds.
- I've tried cutting air alone.
The only things I have not tried at the moment are subbing in a new power supply (48VDC 1000W), changing out the G540 and making use of some sort of breakout board which will accept the 3.3V signals from the LPT card and output at 5V so that I am not operating near the low end of the G540 input specs.
I am attaching a picture of a part which illustrates the problem.
Last edit: 28 Jan 2015 08:54 by jorsborn.
28 Jan 2015 09:38 #55405 by alan_3301
Replied by alan_3301 on topic Losing My Way
Looks like either spindle or Z axis needs to be trammed, or you are losing steps on the Y axis.
Are you sure the gantry is racking?
28 Jan 2015 09:43 #55406 by jorsborn
Replied by jorsborn on topic Losing My Way
The Z axis may need to be trammed (it is close) but I would think if that was the problem I'd see a very gradual progression of the offset. Here the offset is created in an instant. In this particular instance the gantry did not "rack" as it typically does with a large pop. This appears, like you say, that the y axis is losing steps. The depth of cut here was about 0.100" and the overall stock height was 0.944". So, it was ok until about the last 0.300".
28 Jan 2015 19:39 #55415 by alan_3301
I would have a feature somewhere on the table that you can verify if you have lost steps or not.
Set up your job, zero part origin, then jog / probe to feature edges and record coordinates.
Then when the job is finished, or you think you missed steps at some point, go back to check if the coordinates match as before.
Can you describe your machine motion and drive? or post a picture?
I know you said you checked the motor linkages, but if you have timing pulleys, or shaft couplers that use a set screw,
they can shift at totally inconsistent times, and be difficult to see.
I would recommend getting a fine tip paint pen, and putting witness marks on all rotating components that join to another.
On the motor shaft, coupler, and leadscrew for example.
or if you have belt reduction, on all the pulleys and shafts.
The key is to get a pen tip that is as narrow as possible, and draw the lines exactly co-linear.
So if it does slip, you wil be able to see clearly.
28 Jan 2015 19:58 #55416 by cncbasher
Replied by cncbasher on topic Losing My Way
looks to me more mechanical , as the gantry is not stable , and either or the gantry is flexing under load or weight , have you a picture of the machine handy , showing it'sa build ?
28 Jan 2015 22:17 - 28 Jan 2015 22:21 #55418 by BigJohnT
Replied by BigJohnT on topic Losing My Way
A 4' x 8' gantry running steppers with a G540 and cutting metal does not seem like a good fit. Voltage = Power when talking steppers and your at 50v or less so you don't have much power. I run my plasma (54" aluminum gantry) with G203v's that can take 80v. I'm running 68v but I'm not cutting metal. I don't know what rpm your steppers are turning when you cut but as rpm increases torque decreases.
If the problem is the stair stepping seen at the bottom of the pocket you could be loosing steps from side loads while cutting. What voltage is your power supply now?
JT
Last edit: 28 Jan 2015 22:21 by BigJohnT.
28 Jan 2015 23:13 #55422 by alan_3301
I cut aluminum on my diy machine with nema 34 steppers w/ g201x's @ 48v with a 1/4" 2 flute carbide @ 0.080" DOC and 50ipm
I have done the same with a nema 23 g540 driven machine, but with a smaller DOC.
I have cut as deep as 1.125"
In both cases, the finish isn't great, you can see some ripples and variations, but nothing like in the pictures posted.
I didn't realize the g201's were good for 80v, Now you have me thinking about upgrading my power supply!
Thanks alot BigJohnT :P
28 Jan 2015 23:14 #55423 by alan_3301
jorsborn are you good about clearing chips out of the slot?
Maybe the bit is getting gummed up at the lower depths and causing increased effort on the axis motors leading to lost steps?
29 Jan 2015 01:05 - 29 Jan 2015 01:13 #55425 by jorsborn
Thanks all for the responses. I am attaching a picture of the gantry as well as the linkage. The build is mostly based on the structure developed by CNC router parts.
Alan, in this particular instance I am not good about clearing the chips as it gets deep into that slot. I can't say for sure that this is not a contributing factor but I do know that the gantry racks when simply cutting air on some files. There must be particular moves which exacerbates the problem because some files are really problematic. The pen idea is a smart one and I think I'll have a go with that. I'll report back.
The material being cut here is delrin. I am running at approximately 800 SFM (0.25" diameter carbide cutter, 12,000 RPM). My feed rate is set to 30 ipm.
My ini configuration file is below:
# Generated by stepconf at Sun Jul 28 22:35:21 2013
# overwritten when you run stepconf again
[EMC]
MACHINE = router
DEBUG = 0
[DISPLAY]
DISPLAY = axis
#PREFERENCE_FILE_PATH = gmoccapy_preferences
EDITOR = mousepad
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 10.0
INTRO_TIME = 5
PROGRAM_PREFIX = /home/jorsborn/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
EMBED_TAB_NAME = Camera
EMBED_TAB_LOCATION = ntb_user_tabs
#EMBED_TAB_COMMAND = ./camview-emc-f1oat.py -v 1280x720 -C camview.cfg -g cam.ui -H campins.hal  -w {XID}
#PYVCP = custompanel.xml
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 30000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = router.hal
HALFILE = xhc-hb04.hal
#HALFILE = joypad.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
MDI_COMMAND = G38.2 Z-2 f16
MDI_COMMAND = G10 L20 P0 Z.062
MDI_COMMAND = G0 Z2
MDI_COMMAND = G0 X0 Y0 Z0
MDI_COMMAND = G0
MDI_COMMAND = G0
MDI_COMMAND=G10 L20 P1 X0
MDI_COMMAND=G10 L20 P1 Y0
MDI_COMMAND=G10 L20 P1 Z0
MDI_COMMAND=G0 X0 Y0 Z0
[TRAJ]
AXES = 4
COORDINATES = X Y Z Y
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 36.00
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 100.00
MAX_LINEAR_VELOCITY = 300.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 120
MAX_ACCELERATION = 40
STEPGEN_MAXACCEL = 80
SCALE = 1736.237
FERROR = 1
MIN_FERROR = 0.01
MIN_LIMIT = -.5
MAX_LIMIT = 49.5
BACKLASH = 0.005
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 120
SCALE = 1736.237
FERROR = 1
MIN_FERROR = 0.01
MIN_LIMIT = -.5
MAX_LIMIT = 99.0
BACKLASH = 0.005
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 3
MAX_ACCELERATION = 10
STEPGEN_MAXACCEL = 25
SCALE = 4000
FERROR = 1
MIN_FERROR = 0.01
MIN_LIMIT = -6.0
MAX_LIMIT = 6.0
HOME_OFFSET = 0.0
[AXIS_3]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 120
SCALE = 1736.237
FERROR = 1
MIN_FERROR = 0.01
MIN_LIMIT = -.5
MAX_LIMIT = 99.0
BACKLASH = 0.005
HOME_OFFSET = 0.0
Last edit: 29 Jan 2015 01:13 by jorsborn.
29 Jan 2015 01:28 - 29 Jan 2015 01:30 #55426 by alan_3301
That looks almost identical to my machine. I have a 4x4' cncrouterparts machine.
The #1 problem people have is with the motor pulleys slipping.
as you know, the set screw is tiny, and you may not have a flat on the motor shaft for it to rest against.
I used loctite on the interface between the motor shaft and the belt pulley, then with a dab of loctite on the threads, tightened the set screw until almost rounding the hex off.
I haven't had a problem yet. If I ever need to dissassemble it, I will most likely need a gear puller, and will probably damage the belt pulley, but I can live with that, as long as it isn't slipping.
one more thing, you won't be able to see where it slipped, unless you mark it, or take it apart and see the gouges where the set screw was rubbing on the motor shaft.
They are usually tight and secure, up until they slip, change direction and get jammed up again, until it all happens again at some point.
Is your accel a little high for Y at 40? I think I run like 75 for Z, 50 for X and 25 for Y
Last edit: 29 Jan 2015 01:30 by alan_3301. Reason: 50 --> 40
Time to create page: 0.121 seconds
