Boot Problem
04 Apr 2015 23:01 #57526 by Robert Dunn
Replied by Robert Dunn on topic Boot Problem
It looks like update-grub is not doing its job. I tried running it in terminal, and it flashed a couple of lines on the screen and exited. Any suggestions?
04 Apr 2015 23:48 #57528 by ArcEye
Replied by ArcEye on topic Boot Problem
The File I changed was different than that in the link above. I changed "quiet splash" to "nosplash" in var/lib/ucf/cache/:etc:default:grub. A note in this file says to run update-grub after to update grub.cfg. I did this, but it didn't update that file (creation date didn't change).
I think that is just a backup, you need to change /etc/default/grub
...... it flashed a couple of lines on the screen and exited. Any suggestions?
Not without knowing what the error messages were, no.
You need to change the line
GRUB_CMDLINE_LINUX_DEFAULT="put your options here
then run update-grub
It probably did not change grub.cfg because it could not find anything different from the last time it was run
05 Apr 2015 01:52 - 05 Apr 2015 06:25 #57530 by Robert Dunn
Thanks for the new info. I changed the /etc/default/grub file in the place you said. Update-grub still does not run. When I run it in terminal, I can just make out one of the words it flashes, which is "can't find." The file I'm running is usr/lib/grub-legacy/update-grub.
If I could step through update-grub, I might be able to see what's happening.
Last edit: 05 Apr 2015 06:25 by Robert Dunn.
05 Apr 2015 08:17 #57540 by Robert Dunn
I ran bash on update-grub, and see it is looking for /boot/grub/device.map. Device.map doesn't exist there or anywhere else in the file system. Am I up a creek? Should I contact Sherline, or do you have other ideas? I could potentially modify grub.cfg directly, but it sounds dangerous to me.
Comments?
As always, thanks.
Bob
05 Apr 2015 13:46 #57542 by ArcEye
That confuses me, sounds like GRUB 1.9 not 2.0
Can you do a directory print of /boot
cd to it in a terminal and run something like
ls -ld $(find .) > contents.txt
and attach contents.txt that is generated.
06 Apr 2015 02:53 #57557 by Robert Dunn
I'm going to give this a rest. I have sent an email to Sherline asking them to resolve it. I'll update this thread when I have more news.
Bob
Time to create page: 0.133 seconds
