Newb plasma table help, love the look on Linux CNC
- BigJohnT
- Thank you received: 1176
17 Jun 2015 05:29 - 17 Jun 2015 05:30 #59898
by BigJohnT
Replied by BigJohnT on topic Newb plasma table help, love the look on Linux CNC
Just for your information you can run a plasma without a THC, I did it for a year. Can't cut corrugated roofing but if your material is flat and you have a water table to prevent warping you can cut a lot before you get a THC. Can you attach the config file for the Proma 150? $300 seems like a lot for THC but if your coming from Mach your used to paying a lot.
JT
JT
Last edit: 17 Jun 2015 05:30 by BigJohnT.
- WillyInAus
23 Jun 2015 03:36 #60068
by WillyInAus
Replied by WillyInAus on topic Newb plasma table help, love the look on Linux CNC
Hi John it gets even more expensive in Australia lol we just grin and bear it.
I ordered from Poma on ebay on Wednesday and had it Monday not bad for deliver actually was a bit shocked, I will probably order a THC10 as well to give a go when and if they have them in stock as they are quite cheap
and would like to see the difference.
Time to create page: 0.051 seconds
