Manual Toolchange with tool length offset
23 Jun 2015 16:08 #60083 by racedirector
Manual Toolchange with tool length offset was created by racedirector
While searching for how to copy what my Mach3 screenset does I found this:
in which the screen seems to differ from what is available in the sim menu. Does anyone know where this screen may be available?
And while I am here, what is the best method to transfer this functionality into my live version of axis. Being a newbie to LinuxCNC has it's pitfalls as I don't want to mash a bit into hard places on my machine but to do it properly from the outset.
Any help would be appreciated
Cheers
23 Jun 2015 17:38 #60085 by BigJohnT
Replied by BigJohnT on topic Manual Toolchange with tool length offset
That is a GladeVCP panel. You might contact the author and ask for a copy.
JT
23 Jun 2015 17:41 #60086 by Rick G
Replied by Rick G on topic Manual Toolchange with tool length offset
And look here...
github.com/araisrobo/linuxcnc/blob/maste...ool-length-probe.ngc
softsolder.com/2010/04/14/emc2-ugliest-t...-probe-station-ever/
Rick G
23 Jun 2015 18:58 #60087 by racedirector
Replied by racedirector on topic Manual Toolchange with tool length offset
Thanks Rick
Ever helpful as usual, appreciate it.
I also found this: linuxcnc.org/index.php/english/forum/10-...h-off?start=30#48235 and that seems to fit the bill perfectly. Got to pose a question in that one about turning the spindle back on after the whole change routine (the routine turns it off)
Cheers
24 Jun 2015 20:33 #60110 by racedirector
As in my post above this one, I have now implemented the code to do the manual touchoff as per the instructions in that thread. However this seems to have introduced a problem. Whenever I load a gcode file now that has M6 T whatever I get LCNC telling me there is a problem with the file near Line 1 with an Unknown Operation.
These files loaded fine before I implemented the custom M6 code and I have no idea why they are failing now. I can only suspect it has something to do with the M06 T1 line. I have tried taking the line numbering out, changing the M06 to M6, changing the order to M06 T1 and M6 T1 etc etc, all to no avail.
The start of the file is below.
N100 G00 G21 G17 G90 G40 G49 G80
N110 T1 M06
N120 G00 Z20
N130 S21000 M03
N140 G00 X5.74 Y393.85
N150 G00 Z0.0
N160 G01 Z-2.56 F10000
Anyone know what might be going on and how I cure the problem? Would once again appreciate any pointers
Cheers
25 Jun 2015 00:08 #60112 by BigJohnT
Did you edit the G code file in windows? The snipped looks normal to me. LinuxCNC ignores line number so you don't need them.
JT
25 Jun 2015 04:45 #60119 by racedirector
JT. the weird thing is if I comment out the remap commands in my ini the file will load fine.
25 Jun 2015 05:31 #60121 by BigJohnT
Sounds like a problem with your remapping code.
JT
25 Jun 2015 05:56 #60122 by racedirector
Thats what I suspect too but I am not versed in it enough to know where to look: It this one:
O<tool-change> SUB
( Filename: tool-change.ngc )
( LinuxCNC Manual Tool-Change Subroutines for Milling Machines version 1.1: subroutine 1/2 )
(  BEFORE USING CHANGE "CONFIGURATION PARAMETERS" BELOW FOR YOUR MACHINE! )
( In the LinuxCNC .ini config file, under the [RS274NGC] section add: )
(    # change/add/use SUBROUTINE_PATH to point to the location where these tool-change subroutines are located: )
(    SUBROUTINE_PATH = /home/linuxcnc/linuxcnc/nc_files )
(    REMAP=M6    modalgroup=6 ngc=tool-change )
(    REMAP=M600  modalgroup=6 ngc=tool-job-begin )
( and under the [EMCIO] section add: )
(    TOOL_CHANGE_AT_G30 = 0 )
( and ensure neither TOOL_CHANGE_POSITION nor TOOL_CHANGE_QUILL_UP is set. )
( In the LinuxCNC .hal config file, map some input pin to be the probe input, e.g.: )
(    net probe-z parport.0.pin-12-in => motion.probe-input )
( Usage: M6 in the g-code will invoke a manual tool change with automatic tool height adjustment. )
(        M600 is used at the beginning of the first g-code file of a job so that the next M6 will measure the tool for reference )
(             instead of caluculating a tool length offset. It can also be invoked manually through the MDI before a job starts. )
( General theory of operation: touches each tool off to the tool height sensor. The first tool is used as the reference, all )
(     subsequent tools adjust the tool offset. The tip of the tool is always placed back at the position it started in before )
(     any of the subroutines are called. It is moved away by raising Z to _TravelZ before moving towards the switch, and when )
(     moving back from the switch again moves at height _TravelZ before going straight back down to the original position. Set )
(     all necessary modes to ensure correct operation no matter what state the program is in when this is called. We eliminate )
(     almost all side effects by saving and restoring the modal state. )
( Side effects: sets G30, sets motion mode to G1. )
(------------------------------- CONFIGURATION PARAMETERS ----------------------------------------------)
#<_UseInches> =           0     ( set to 1 to use inches here, or 0 to use millimeters; should match units on tool.tbl dimensions )
#<_TravelZ> =          41.0     ( machine Z coordinate for travelling, typically near max Z to avoid ever hitting the work )
#<_TravelFeed> =     1000.0     ( feedrate used for general Z moves when avoiding G0 )
#<_ProbeX> =          145.0     ( machine X coordinate of switch/touch-off plate )
#<_ProbeY> =            0.0     ( machine Y coordinate of switch/touch-off plate )
#<_ProbeFastZ> =        5.0     ( machine Z coord to move to before starting probe, longest tool should not touch switch at this Z )
#<_ProbeMinZ> =       -37.0     ( machine Z coord to stop probe, shortest tool must touch switch at this Z, must be > min Z )
#<_ProbeRetract> =      1.5     ( small distance to retract before approaching switch/touch-off plate second time )
#<_ProbeFastFeed> =   400.0     ( feed rate for moving to _ProbeFastZ )
#<_ProbeFeed1> =       80.0     ( feed rate for touching switch/touch-off plate first time )
#<_ProbeFeed2> =       10.0     ( feed rate for touching switch/touch-off plate second time )
#<_ToolChangeX> =       0.0     ( machine X coordinate to pause at for manual tool changing )
#<_ToolChangeY> =     -50.0     ( machine Y coordinate to pause at for manual tool changing )
#<_MistOnDuringProbe> =   1     ( set to 1 for mist, or 2 for coolant, or 0 for nothing during probing, to clear switch of swarf )
O100 IF [ EXISTS[#<_ToolDidFirst>] EQ 0 ]
        #<_ToolDidFirst> = 0
O100 ENDIF
O105 IF [ #<_ToolDidFirst> EQ 0 ]
   G49                                         ( clear tool length compensation prior to saving state if this is first time )
O105 ENDIF
M6                                             ( do the normal M6 stuff )
M70                                            ( save current modal state )
M9                                             ( turn off coolant, will be restored on return if it was on )
M5                                             ( turn off spindle, cannot be on during the probe )
G[21 - #<_UseInches>]                          ( use inches or millimeters as required here, units will be restored on return )
G30.1                                          ( save current position in #5181-#5183... )
G49                                            ( clear tool length compensation )
G90                                            ( use absolute positioning here )
G94                                            ( use feedrate in units/min )
G40                                            ( turn cutter radius compensation off here )
O200 IF [ #<_ToolDidFirst> EQ 0 ]
  G53 G1 F[#<_TravelFeed>] Z[#<_TravelZ>]      ( go to high travel level on Z )
  G53 G0 X[#<_ProbeX>] Y[#<_ProbeY>]           ( to probe switch )
  G53 G1 F[#<_ProbeFastFeed>] Z[#<_ProbeFastZ>]( move tool closer to switch -- we shouldn't hit it )
  G54 G1 F[#<_ProbeFeed1>] G91                 ( use relative positioning )
  O101 IF [ #<_MistOnDuringProbe> EQ 1 OR #<_MistOnDuringProbe> EQ 2 ]
    M[7 + #<_MistOnDuringProbe> - 1]           ( turn on mist/coolant )
  O101 ENDIF
  G38.2 Z[#<_ProbeMinZ> - #<_ProbeFastZ>] F[#<_ProbeFeed1>]    ( trip switch slowly )
  G0 Z[#<_ProbeRetract>]                       ( go up slightly )
  G38.2 Z[#<_ProbeRetract>*-1.25] F[#<_ProbeFeed2>]   ( trip switch very slowly )
  M9                                           ( turn off mist )
  G90                                          ( use absolute positioning )
  #<_ToolZRef> = #5063                         ( save trip point )
  #<_ToolZLast> = #<_ToolZRef>                 ( save last tool Z position )
  G53 G1 F[#<_TravelFeed>] Z[#<_TravelZ>]      ( return to safe level )
  G53 G0 X[#5181] Y[#5182]                     ( return to where we were in X Y)
  G53 G1 F[#<_TravelFeed>] Z[#5183]            ( return to where we were in Z )
  M72                                          ( restore modal state )
  #<_ToolDidFirst> = 1                         ( we have been in this section to set reference value already )
O200 ELSE
  G53 G0 X[#<_ToolChangeX>] Y[#<_ToolChangeY>] ( nice place for changing tool )
  O107 IF [#<_UseInches> EQ 1 ]
    #<ToolDiamIn> = #5410
    #<ToolDiamMM> = [ #<ToolDiamIn> * 25.4 ]
  O107 ELSE
    #<ToolDiamMM> = #5410
    #<ToolDiamIn> = [ #<ToolDiamMM> / 25.4 ]
  O107 ENDIF
  O102 IF [ #<_current_tool> EQ 0 AND #<ToolDiamIn> EQ 0 ]
    (MSG, Change tool then click Resume )
  O102 ELSE
    (DEBUG, Change to tool #<_current_tool> with diameter #<ToolDiamMM>mm, #<ToolDiamIn>in then click Resume )
  O102 ENDIF
  M0                                           ( pause execution )
  G53 G0 X[#<_ProbeX>] Y[#<_ProbeY>]           ( to high place directly over switch )
  O103 IF [ #<_MistOnDuringProbe> EQ 1 OR #<_MistOnDuringProbe> EQ 2 ]
  O103 ENDIF
  #<_ToolZ> = #5063                            ( save new tool length )
  G43.1 Z[#<_ToolZ> - #<_ToolZRef>]            ( set new tool length Z offset, we do this now to show operator even though it has to be set again after M72 )
  G53 G1 F[#<_TravelFeed>] Z[#<_TravelZ>]      ( return to high travel level )
  G53 G1 F[#<_TravelFeed>] Z[#5183 - #<_ToolZLast> + #<_ToolZ>]   ( return to where we were in Z, ajusting for tool length change )
  #<_ToolZLast> = #<_ToolZ>                    ( save last tool length )
  G43.1 Z[#<_ToolZ> - #<_ToolZRef>]            ( set new tool length Z offset )
O200 ENDIF
O<tool-change> ENDSUB
M2
I have gone through this file line by line looking up all the codes I didn't know, all to no avail.
In my ini I have the "required' lines as per the post, as in:
and
25 Jun 2015 11:33 #60123 by racedirector
JT, I should have clicked when you said "edited in Windows".
I am on Xbuntu 12.04 and edit any text based files in Leafpad. For some reason if I open a file and just save it something goes wrong. If I do a Save As and overwrite the file, ensuring the line endings ar LF it works. Having been on a Mac for years and running Windows for the CNC for years I have no idea what is going on in Ubuntu to save the files incorrectly
