Manual Toolchange with tool length offset
- BigJohnT
- Thank you received: 1176
25 Jun 2015 17:19 #60125
by BigJohnT
Replied by BigJohnT on topic Manual Toolchange with tool length offset
I've never used remap or leafpad so I'm a bit lost about them. I usually use gedit on linux and notepad++ on windows. If your editor changes the line endings LinuxCNC will not like it.
JT
JT
- racedirector
- Thank you received: 42
25 Jun 2015 18:31 #60126
by racedirector
Replied by racedirector on topic Manual Toolchange with tool length offset
Still don't know what Leafpad does or why it does it, just installed gedit instead. I'm on Xbuntu 12.04.4 so the xfce equivilent must have been Leafpad.
- Rick G
- Thank you received: 155
26 Jun 2015 14:50 #60148
by Rick G
Replied by Rick G on topic Manual Toolchange with tool length offset
Check that you have the subroutines in the correct directory.
Rick G
# change/add/use SUBROUTINE_PATH to point to the location where these tool-change subroutines are located:
Rick G
- racedirector
26 Jun 2015 15:18 #60150
by racedirector
Hi RIck
It's all good now. Turned out to be incorrect line endings in the file, when I resaved it as LF it worked straight away. Kinda had me stumped for a while....
