Program exceeds machine limits error using G33 (in 2.7.0~pre7)
- tome
- Thank you received: 11
01 Sep 2015 11:51 #61978
by tome
Program exceeds machine limits error using G33 (in 2.7.0~pre7) was created by tome
We get the error below when we try to run G33. The program runs if we select "Run Anyway" - it doesn't exceed the limits yet the error always comes up. What would cause this?
Here is an example of code that causes it:
; score a workpiece, n times around its circumference
#<workDiameter> = 0.75
#<safeXOffset> = 0.025
#<workRadius> = [ #<workDiameter>/2 ]
#<safeX> = [#<workRadius> + #<safeXOffset>]
#<startZ> = -0.300
#<depthOfCut> = 0.005
#<numberOfCuts> = 2
; need to feed twice (in _and_ out) the depth of cut *
; <numberOfCuts> per revolution
#<radialFeedRate> = [2 * #<depthOfCut> * #<numberOfCuts>]
(debug, radial feed rate: #<radialFeedRate>)
G8
M4 S100
G0 X#<safeX>
G0 Z#<startZ>
G1 X#<workRadius> F5
#100 = #<numberOfCuts>
o100 WHILE [#100 GT 0]
G33 X[#<workRadius> - #<depthOfCut>] K#<radialFeedRate> (feed in)
G33 X#<workRadius> K#<radialFeedRate> (feed out)
#100 = [#100 - 1]
o100 ENDWHILE
G0 X#<safeX>
G0 Z#<startZ>
M5
M2
#<startZ> = -0.300
#<numberOfCuts> = 2
G8
M4 S100
G0 X#<safeX>
G0 Z#<startZ>
#100 = [#100 - 1]
o100 ENDWHILE
G0 X#<safeX>
G0 Z#<startZ>
M5
M2
- BigJohnT
- Thank you received: 1177
01 Sep 2015 19:01 #61989
by BigJohnT
Replied by BigJohnT on topic Program exceeds machine limits error using G33 (in 2.7.0~pre7)
That code does not cause an error when run in the Axis lathe sim. Check to see if you have some G92 offsets left over from another program.
JT
JT
- tome
01 Sep 2015 20:20 #61993
by tome
Nope, no G92 offsets in place...
Replied by tome on topic Program exceeds machine limits error using G33 (in 2.7.0~pre7)
JT
- tome
01 Sep 2015 20:28 #61995
by tome
It doesn't seem to be a position problem because when commanded to run regardless, it moves to the workpiece and takes light cuts as expected.
It shouldn't be a feed rate problem either. In the code, it is asked to move 0.005" 4 times in a single revolution. That's 0.02" in total. And at 100 rpm, that's only 2 ipm.
It is being asked to reverse direction so the trajectory planner could be throwing up its hands? But that doesn't explain why it complains about the Z axis in addition to X; there aren't many Z moves in it and there are no Z movements in G33.
My configs are attached if that gives a clue...
- BigJohnT
01 Sep 2015 21:07 #61997
by BigJohnT
You have max limits of 0.001 for both axes, when I run the program in the simulator the X axis ends up at 0.400 which is greater than 0.001 so I would expect and error but how it runs for you is unknown to me. Your not selecting a tool in your G code so I assume your doing some touch off before running? Seems to me the last line should be G) Z#<safeZ> but you don't define that.
JT
JT
- cncbasher
- Thank you received: 288
01 Sep 2015 22:38 #62007
by cncbasher
Replied by cncbasher on topic Program exceeds machine limits error using G33 (in 2.7.0~pre7)
for me the z axis is wrong ?
MIN_LIMIT = -2.106
MAX_LIMIT = 0.001
this is a lathe yes , so ok you have reversed the stepper drive to get the motors running in the correct direction , i would prefer to have the software correct and
reverse the stepper motor wires so the sense of the software is correct , in a sense you have ferror as 1 where it should be -1 to have the same sense
these ferror limits you have set , are just not obtainable using stepper motors .
you just dont need them for steppers , so the ferror etc are pure software calculation , and cant be relied on in real life as theirs no feedback
i'd open the max limit to 0.2 .
it's far better to match the machine to the run in the correct sense , even if it means rewiring a stepper driver to do it , then at least the calculations will run the correct way
this can catch you out for instance on a spindle when screw cutting .
be a bit more conservative with values and the problem you have should go away .
MIN_LIMIT = -2.106
MAX_LIMIT = 0.001
- tome
02 Sep 2015 00:45 - 02 Sep 2015 01:10 #62016
by tome
I think it is the 0.001 max limit that is causing it, but if I set it larger, to say 0.5 or higher don't I run the risk of sending my axis beyond it's zero point? This is a back tool lathe and my as such moves from X=0 to X= -2.1 and Z=0 to Z= -7 (or thereabouts). Doesn't setting MAX_LIMIT to 0.5 mean it can move back beyond it's home (zero) point in a program?
The program I posted doesn't do tool loading as we just did a simplified example of the issue. We loaded tool 1 and touched it off outside the program and it doesn't end up a 0.400 (or anywhere outside our limits).
-Tom
ps: I retract the above statement. I DON'T think the max limit is the culprit. After loading our tool #1 we don't go anywhere near any of the limits. Also, my machine cannot physically move more than a small amount beyond the home point (zero) so I cannot set MAX_LIMIT more than a few thou and be safe. I think this is a red herring.
JT
-Tom
Last edit: 02 Sep 2015 01:10 by tome.
- tome
02 Sep 2015 00:56 - 02 Sep 2015 00:59 #62018
by tome
I guess I am not sure what "correct sense" means to you, or how that would change how the UI works now - which has been fine. This is a back-tool lathe and from everything I read setting this up I do have it configured to act correctly for that configuration. I don't know how I would rewire my 5-phase stepper motors to change anything. It took me several iterations to get them wired to work correctly, I'd certainly rather not try to re-wire them...
But you say my ferror should be -1 (rather than 1), is that true? Also, you say my ferror limits are not obtainable. I think those values are from pncconf wizard, I don't think I configured them. I'm not really sure what they should be, do you have more realistic values I should use? Or are you saying I should just remove them from the config entirely?
Thanks,
-Tom
ps: We have cut a bunch of threads and they have come out great, not sure how the config can cause a problem here...?
MIN_LIMIT = -2.106
MAX_LIMIT = 0.001
Thanks,
-Tom
Last edit: 02 Sep 2015 00:59 by tome.
- BigJohnT
02 Sep 2015 02:56 #62024
by BigJohnT
Can you elaborate on how you loaded the tool and touched off? Does this lathe have a turret and use the tool table?
And no, you don't want to set the limits outside the physical limits.
JT
-Tom
JT
- tome
02 Sep 2015 09:32 #62037
by tome
The lathe has a turret. We do M6 T1 which loads the tool and also set tool length offset (G43 I think). A button in Glade side panel for each tool runs a script actually. Tools are first touched off to a fixture (wired to Mesa 7i84 input) that is mounted on the spindle head in both Z and X (using G38.something). Then tool 1 is set to the end of workpiece and Z is touched off (G54) and then set on known diameter (or radius since we usually have G8 set) and X is touched off (G54 again).
Tom
Tom
Time to create page: 0.974 seconds
