Heidenhain EXE-602 Configuration
21 Nov 2015 21:41 #65628 by csbrady
Heidenhain EXE-602 Configuration was created by csbrady
I am doing a refit of a Bridgeport Interact mill and have some EXE 602 boxes to convert the 11us sine wave signal to TTL. The 602's have 5 jumpers inside to set configuration options. For the life of me I cannot find anything about these. The manuals have excruciating detail about everything but these jumpers. Anyone out there have information about the jumpers?
21 Nov 2015 22:18 #65630 by cmorley
Replied by cmorley on topic Heidenhain EXE-602 Configuration
What makes you think the switches are for user configuration options?
I have a 602 manual it doesn't mention anything to give me the idea that I can change anything.
Are you trying to change the interpretation rate?
Chris M
The following user(s) said Thank You: csbrady
22 Nov 2015 03:55 #65639 by Diederik
Replied by Diederik on topic Heidenhain EXE-602 Configuration
I Retrofitted my deckel, and also have sine wave heidenhain scales, and I ended up from the scale /linear encoder, wired directly into a Schmidt trigger, and from that into my 7i77. This converted the sine to square wave. It gave me 0.005mm resolution, which is good enough for me. I have a friend who sells another device that takes the 0.005mm sine wave, and breaks it down to give you a 0.001mm resolution square wave. He sells them for about ZAR 1000, which is about USD 80 each.
22 Nov 2015 05:08 #65640 by csbrady
Replied by csbrady on topic Heidenhain EXE-602 Configuration
The manuals indicate that the box can be configured for no interpolation or 5 fold. Also the width of the fault detection pulse, and the index pulse can be configured. There is also an option for tristate for the outputs if there is an error. I can figure out the settings with a scope if I have to. It's really odd that the manuals offer a lot of detail about the options with nary a word about how to set them.
I already have the 602's. If I am not able to get them to work it's nice that there are other options.
22 Nov 2015 05:35 #65642 by cmorley
interesting my manual doesn't mention these option AFAIK.
If you figure it out please post your results.
My 602s are already 5 fold - maybe I could open one and show you the difference?
Chris M
22 Nov 2015 06:03 #65643 by csbrady
At last I found what I am looking for. The only manuals I could find were for for an exe602E and I have exe602D's. I managed to find the manual for the exe602D and on page 18 are the jumper settings, Hallelujah! The first two jumpers are used to set 0 or 5 fold. My 4 exe602D's were all set differently and mostly incorrectly so it would have been a pain to sort this out without the manual.
I am not sure if the exe602E has the same jumpers, but the manual certainly implies the the unit has configuration options.
07 Jan 2016 15:05 #68017 by csbrady
I discovered that the settings in the manual titled EXE 602D EXE 604C EXE 605S, dated 2/2003 are absolutely incorrect for the EXE 602D and do not work. Here are the correct settings that Heidenhain tech support sent me:
The following user(s) said Thank You: Willemsjos
16 Feb 2018 23:58 #106056 by cmorley
I'm wondering if you could post the other manual page that you had.
My 602 is either set wrong or has different functions.
Chris M
17 Feb 2018 03:04 #106062 by csbrady
I don't have the old manual that had the settings that were incorrect for my 602Ds. Sorry! I have the full manual for the excerpt that poster above if that would help.
17 Feb 2018 04:45 #106063 by cmorley
Sure if you don't mind
Chris M
Time to create page: 0.803 seconds
