Heidenhain EXE-602 Configuration
06 Dec 2018 05:12 #121925 by nkp
Replied by nkp on topic Heidenhain EXE-602 Configuration
Could you send me the documentation EXE
14 Sep 2020 03:35 #182050 by BradMck
Replied by BradMck on topic Heidenhain EXE-602 Configuration
Hi There,
I am fitting 3 Heidenhain EXE 602 to a Maho700 Milling machine and using a Esson ES14 DRO (eventually heading to the Linux System) I can get the X Axis to read the correct distance but the X and Y Axis only read 25mm but travel 50mm. I have 2 options in the DRO for resolution 0.005 & 0.001. When set at 0.005 and physical travel of 50mm the DRO displays 125mm & Setting of 0.001 physical travel of 50mm DRO Displays 25mm.
Is there anything that I am Missing?
Thanks Brad
29 Sep 2021 10:02 #221814 by sivaraj
Replied by sivaraj on topic Heidenhain EXE-602 Configuration
I suspect your scale grating period is different.Check your scale type.
It could be 40um.
If scale grating period is 20um and with EXE602 5x multiplier you will get 1um resolution.
To get 1um resolution with a 40um scale grating pitch you will require a 10x multiplier
Time to create page: 0.851 seconds
