Heidenhain EXE-602 Configuration
10 years 9 months ago #68017 by csbrady
I discovered that the settings in the manual titled EXE 602D EXE 604C EXE 605S, dated 2/2003 are absolutely incorrect for the EXE 602D and do not work. Here are the correct settings that Heidenhain tech support sent me:
The following user(s) said Thank You: Willemsjos
8 years 8 months ago #106056 by cmorley
I'm wondering if you could post the other manual page that you had.
My 602 is either set wrong or has different functions.
Chris M
8 years 8 months ago #106062 by csbrady
I don't have the old manual that had the settings that were incorrect for my 602Ds. Sorry! I have the full manual for the excerpt that poster above if that would help.
8 years 8 months ago #106063 by cmorley
Sure if you don't mind
Chris M
7 years 10 months ago #121925 by nkp
Could you send me the documentation EXE
6 years 1 month ago #182050 by BradMck
Hi There,
I am fitting 3 Heidenhain EXE 602 to a Maho700 Milling machine and using a Esson ES14 DRO (eventually heading to the Linux System) I can get the X Axis to read the correct distance but the X and Y Axis only read 25mm but travel 50mm. I have 2 options in the DRO for resolution 0.005 & 0.001. When set at 0.005 and physical travel of 50mm the DRO displays 125mm & Setting of 0.001 physical travel of 50mm DRO Displays 25mm.
Is there anything that I am Missing?
Thanks Brad
Time to create page: 0.154 seconds
