LinuxCNC, Plasma, THC questions
- Greolt
10 years 11 months ago #65991
by Greolt
Replied by Greolt on topic LinuxCNC, Plasma, THC questions
Thanks Tom
Looks like I will be going for a Proma or equivalent simple THC. Then I will be looking at your recommended setup.
10 years 11 months ago #66069
Replied by andypugh on topic LinuxCNC, Plasma, THC questions
Have you seen the Mesa THCAD thing? (I am not sure if it is equivalent to the Proma or not)
store.mesanet.com/index.php?route=produc...oduct&product_id=128
- Greolt
10 years 11 months ago #66079
by Greolt
Not in person. Seen it on the Mesa website. Info is a bit light on.
For my needs it would be the 0 - 10v model. It says other circuitry is required for a pilot arc plasma. But does not go into what that might involve. Might just be a series resistor.
I have decided to go for a simple THC like the Proma for now. See how that goes.
andypugh wrote: Have you seen the Mesa THCAD thing? (I am not sure if it is equivalent to the Proma or not)
- Thank you received: 7491
10 years 11 months ago #66080
Replied by tommylight on topic LinuxCNC, Plasma, THC questions
Let us know how it goes, and do pay attention to wiring, even though you can not destroy proma thc, only and only if you wire the 200V line to the 5v input ! that is the only thing i did not test as it is irrational, i have literally tried to destroy one but nothing happened, even reversed the polarity on the power supply (will not turn on), on the 200V input (will show 0V even when plasma is on).
Regards,
Tom
Regards,
Tom
- Greolt
10 years 11 months ago #66081
by Greolt
I know you are a fan of the Proma Tom.
However I have ordered an equivalent THC from my side of the world.
It has high current optos instead of relays and might help it be just a little faster.
I expect it will work much the same with your LinuxCNC setup. It has the same outputs as the Proma. Up, Down, ArcOK
10 years 11 months ago #66084
Fan ??? am i spinning ???
Unfortunately i did not have the chance to try the CandCnc , or any other THC form other manufactures,.
I will be around in case you need any help.
Regards,
Tom
Regards,
Tom
Time to create page: 0.387 seconds
