LinuxCNC, Plasma, THC questions
10 years 11 months ago #66115 by cncbasher
Replied by cncbasher on topic LinuxCNC, Plasma, THC questions
you can order direct from Mesanet also ,
10 years 11 months ago - 10 years 11 months ago #66129 by Greolt
Replied by Greolt on topic LinuxCNC, Plasma, THC questions
One thing I was not sure about is,
Does the THCAD require a Mesa IO card, or can the LPT read it fast enough?
Last edit: 10 years 11 months ago by Greolt.
10 years 11 months ago #66133 by PCW
Replied by PCW on topic LinuxCNC, Plasma, THC questions
You can read it with a standard LPT port (you can divide the output frequency down to 8 KHz or so full scale)
but you do lose speed or resolution because the parallel port is only sampled at say 30 KHz maximum and this determines the
frequency resolution (This may sound a bit strange but the frequency is read as encoder velocity, and encoder velocity resolution
depends on the sample rate, _not_ the input frequency)
10 years 11 months ago #66135 by Greolt
OK I will interpret that as,
To get the full advantage of the THCAD it really needs to be used together with a IO card
10 years 11 months ago #66138 by Greolt
Just looking at the mesa site and the 5i25 IO board.
I assume that that will interface quite nicely with my present LPT break out board. As in not need the 7i76 daughter board.
Now am I missing something in that assumption in relation to interfacing with THCAD?
I don't think I would need the extra IO that the 7i76 would provide. But maybe the THCAD needs something the LPT BoB does not provide.
10 years 11 months ago #66144 by andypugh
Replied by andypugh on topic LinuxCNC, Plasma, THC questions
Greolt wrote: JI assume that that will interface quite nicely with my present LPT break out board. As in not need the 7i76 daughter board.
Possibly...
It depends on whether your breakout has encoder-speed inputs on pins that suit one of the firmwares.
You can't change the layout of pins in the 5i25 in HAL (unlike with a parallel port). The 5i25 is flashed with a bitfile that defines what each pin is for.
If you download the 5i25.zip file from Mesanet, then look in the 5i25/configs/hostmot2 folder and poke through the .pin files to see if any match your BoB. One good candidate would be 5i25_dmmbob1x2.pin
Time to create page: 0.836 seconds
