Missing hm2_eth
- Mtndrew77
21 Dec 2015 00:00 #67182
by Mtndrew77
Missing hm2_eth was created by Mtndrew77
Linux Cnc is failing to start for me. I'm not sure why this module is missing or what it does?
I'm running Ubuntu Precise with Linux Cnc 2.7.3 connected to Mesa 7i76e. Attached is the file with
error messages. Need some help. Thanks in advance
- BigJohnT
- Thank you received: 994
21 Dec 2015 00:26 #67183
by BigJohnT
Replied by BigJohnT on topic Missing hm2_eth
Did you check for missing build dependencies with:
dpkg-checkbuilddeps
I'm assuming you did some kind of build it yourself to get it on precise?
JT
dpkg-checkbuilddeps
JT
The following user(s) said Thank You: Mtndrew77
- Mtndrew77
21 Dec 2015 01:15 #67184
by Mtndrew77
Replied by Mtndrew77 on topic Missing hm2_eth
No i didn't, but I started out with the prepackaged debian-wheezy version and got the same error.
After that I just figured if I'm going to have problems I might as well just go back to the OS i like.
I didn't do anything special for the build I just followed the instructions here.
linuxcnc.org/docs/2.7/html/getting-start...ng_on_ubuntu_precise
- dgarrett
- Thank you received: 297
21 Dec 2015 01:20 #67186
by dgarrett
hm2_eth works for uspace (not rtai)
You didn't post your config files so it is unknown why your configuration attempts to loadrt hm2_eth
Replied by dgarrett on topic Missing hm2_eth
./my_LinuxCNC_machine.hal:8: Can't find module 'hm2_eth' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
- Mtndrew77
21 Dec 2015 01:41 #67188
by Mtndrew77
Attached ini and pncconf
- dgarrett
21 Dec 2015 01:51 #67189
by dgarrett
for hm2_eth, pncconf creates a configuration that will likely work on uspace but not on rtai.
If you want to use hm2_eth, you will need to install a rt-preempt kernel.
Ref: linuxcnc.org/docs/2.7/html/man/man9/hm2_eth.9.html
hm2_eth is only available when linuxcnc is configured with "uspace" realtime.
- Mtndrew77
24 Dec 2015 22:43 #67303
by Mtndrew77
Sucess!! I reinstalled Debian 7 wheezy with the rt-preempt kernel and ran the setname program referenced below. Then she took off.
Thanks Everyone, and Merry Christmas!
Ref: forum.linuxcnc.org/forum/27-driver-board...board?start=10#65737
Time to create page: 0.167 seconds
