Dead in the water on 7i92 config
- dannym
10 Apr 2016 02:10 #73028
by dannym
Replied by dannym on topic Dead in the water on 7i92 config
OK looking better. I ran into several errors where the pin was already driven by something in the X[0] or W[3] sections so I commented out those lines in favor of the Gantry links.
Now, the Y and Z move ok, but ANY attempt to move the gantry (X axis) gives "joint 0 following error". Doesn't matter if the World Mode +/- jog is used, or keyboard, or G0/G1 command. Y and Z move great, X-gantry thriows following error.
.hal enclosed.
.hal enclosed.
- Thank you received: 5326
10 Apr 2016 02:46 #73031
Replied by PCW on topic Dead in the water on 7i92 config
Not sure but one possibility is that you have a thread order problem with the gantry component
( the order of addf statements is important )
I suspect that the gantry read and write should done between motion and PID
If this does not solve the problem, I would widen the following error limits and take a look at
the position command and feedback of the gantry comp, and figure out why they are not tracking
- dannym
10 Apr 2016 03:13 - 10 Apr 2016 03:14 #73034
by dannym
OK my threads are now:
addf hm2_[HOSTMOT2](BOARD).0.read servo-thread
addf gantry.0.read servo-thread
addf gantry.0.write servo-thread
addf pid.0.do-pid-calcs servo-thread
addf pid.1.do-pid-calcs servo-thread
addf pid.2.do-pid-calcs servo-thread
addf pid.3.do-pid-calcs servo-thread
addf hm2_[HOSTMOT2](BOARD).0.write servo-thread
And I changed MAX_ERROR=0.5, then a full 5". Still zero motion, just "joint 0 following error".
I tried putting the addr gantry after the PID calcs too, just to experiment. No diff.
Last edit: 10 Apr 2016 03:14 by dannym.
10 Apr 2016 03:37 #73035
looks like the pid feedback for stepgens 0 and 3 is not there:
net x0pos-fb gantry.0.joint.00.pos-fb pid.0.fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb
net x1pos-fb gantry.0.joint.02.pos-fb pid.3.fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb
also a more minor thing, you must disconnect the feedback-derv pins on PID 0 and 3
- dannym
10 Apr 2016 03:40 - 10 Apr 2016 03:56 #73036
by dannym
Added, now I get "Pin 'pid.0.fb' does not exist"
So, wait. Joiints 0 and 3 are my X-axis. And that's PID 0 and PID 3. Here I've got:
net x1pos-cmd gantry.0.joint.01.pos-cmd => pid.3.command
Accessing joint 1 and 2 in addition to 0. Is that right?
Last edit: 10 Apr 2016 03:56 by dannym.
10 Apr 2016 13:52 - 10 Apr 2016 18:41 #73048
sorry its pid.0.feedback and pid.3.feedback
BTW you can get a list of all available pins with
halcmd show pin
Last edit: 10 Apr 2016 18:41 by PCW. Reason: typo
- dannym
10 Apr 2016 19:57 - 10 Apr 2016 19:58 #73073
by dannym
OK I got an error from using "joint.02" and then repeating "stepgen.00" for the second joint, I think that was supposed to be stepgen.03, so I changed it to:
net x0pos-fb gantry.0.joint.00.pos-fb pid.0.feedback <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb
net x1pos-fb gantry.0.joint.01.pos-fb pid.3.feedback <= hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-fb
Then it conflicted with the prior lines which I removed:
#net x0pos-fb gantry.0.joint.00.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb
Now it loads and runs, but... same problem. I can move around Y and Z. Any attempt to touch X- the gantry- gets a Joint 0 Following Errior with no motion at all. Most recent .hal enclosed.
Last edit: 10 Apr 2016 19:58 by dannym.
10 Apr 2016 20:24 #73076
The hal file looks ok AFAICT now so I think the next step to to trace the motion command and feedback (xpos-cmd and xpos-fb) to see why that are so far apart. The gantry manual says they track the joint values (with an offset added when homing)
- dannym
10 Apr 2016 20:31 - 10 Apr 2016 21:02 #73077
by dannym
OK I noticed that the second motor still uses:
net emcmot.03.enable <= axis.3.amp-enable-out
Whereas the first X-motor doesn't, because amp-enable-out was already defined.
halcmd show pin shows axis.0.amp-enable-out ==> xenable, and axis.3.amp-enable-out ==> emcmot.03.enable
I used:
net xenable axis.0.amp-enable-out => hm2_[HOSTMOT2](BOARD).0.stepgen.00.enable hm2_[HOSTMOT2](BOARD).0.stepgen.03.enable
Is that correct?
I don't have any homing routine yet. The switches are not wired in for this board. I'm a bit confused- when I was using Gantrykins, there was a Joint Mode with 0, 1, 2, 3. So zeroing 0 and 3 made sense. With trivkins, there's X Y Z A. I did the Home Axis button to zero, but A is within X, so this seems... strange.
I also noted that MAX_ERROR=0.5 to try and get it moving... when I commanded it, I tried "g1 x0.1 f1" and that still gives Following Error with no motion, even though it is still less than the allowable error even if it doesn't move. I may not be understanding what that MAX_ERROR is, though,
I used:
Is that correct?
Last edit: 10 Apr 2016 21:02 by dannym.
- dannym
10 Apr 2016 21:47 - 11 Apr 2016 01:26 #73081
by dannym
I tried looking at things with HAL Scope and got nothing and then saw it was simpler to just bring up Show HAL Configuration and see the values.
After a G1 x0.1 F1 (which causes a Folllowing Error), everything's still zero. Including axis.0.motor-pos-cmd and gantry.0.position-cmd. I looked all through the axis.0 and gantry and everything's zero. Only like axis.0.coarse-pos-cmd=-0.0001416667
Last edit: 11 Apr 2016 01:26 by dannym.
