Homing switches not recognized linuxcnc
- Boltonbrass
13 Feb 2016 17:00 #70066
by Boltonbrass
Replied by Boltonbrass on topic Homing switches not recognized linuxcnc
cannot open file ptest.hal is the error message i am running into.
- Boltonbrass
13 Feb 2016 17:02 #70067
by Boltonbrass
I am getting cannot open file ptest.hal
- Boltonbrass
14 Feb 2016 00:13 #70090
by Boltonbrass
I have the ptest.hal working and my z axis home switch does not trigger pin 15 on the ptest. More investigation.
- Boltonbrass
14 Feb 2016 16:01 #70117
by Boltonbrass
I got the ptest working and I parallel port card is not in the right mode. Any thoughts?
- BigJohnT
- Thank you received: 994
14 Feb 2016 16:19 #70118
by BigJohnT
Replied by BigJohnT on topic Homing switches not recognized linuxcnc
Bad switch, faulty wiring... not really enough information to have very many thoughts.
JT
JT
- Boltonbrass
14 Feb 2016 17:10 #70122
by Boltonbrass
The switches are working and are NC two types. Circuit opens when triggered. The breakout board is the same one sold at omc stepperonline.
- Boltonbrass
14 Feb 2016 21:12 #70129
by Boltonbrass
When I run ptest I get pins 10, 12, 13 and 15 are green and triggered. Pin 11 is not. Any suggestions on other diagnostics that I could run?
- BigJohnT
14 Feb 2016 23:14 #70133
by BigJohnT
Do you have a link to the BOB? Pin 11 is an input always so configuration is not a problem. Could be a bad opto on the Bob if they use them. I've had a bad opto on a cnc4pc C1 Bob.
JT
JT
- Boltonbrass
22 Feb 2016 06:04 #70466
by Boltonbrass
I think we have narrowed the problem down to parallel port card.
I have a syba with netmos 9805 chipset.
Time to create page: 0.226 seconds
