- Thank you received: 6
Rounded corners and "rounded down".
- aparecido
- Topic Author
Detail I am simulating the code in the program did not call the machine because I want to let all of software and ready configuration to avoid problems.
Has some setting or option should I enable / disable to change this?
Thank you.
image missing http://s21.postimg.org/nj5zjp31z/print_cnc_Copia.jpg
photoupload
- BigJohnT
- Thank you received: 994
And: linuxcnc.org/docs/2.7/html/user/user-con...#_trajectory_control
JT
- aparecido
- Topic Author
- BigJohnT
JT
- aparecido
- Topic Author
Can post example of how to use the G61 and the G64 command to identical test your test? Thank you.
- Rick G
- Thank you received: 114
When you are in MDI mode the active g codes will be listed on the lower left of the screen.
Rick G
- BigJohnT
aparecido wrote: Hi, so I downloaded the movement speed, literally almost stopped and the same thing happened. The latency you test was less than 17,000 with various things open, including mp3, videos, programs etc.
I did nothing more than run the splash code on the Axis Sim as is.
JT
- aparecido
- Topic Author
Thanks a lot for help, hugs.
- aparecido
- Topic Author
In turbocnc and stepconf jog the motors move correctly, but in Linuxcnc both in jog and the execution of gcode, the engines are stopped.
What should I do? From what already googled, just open the Linuxcnc, out of emergency mode and 'connect' to the homing and run gcode in my case using the example he carries when opening the program.
aparecido wrote: In turbocnc and stepconf jog the motors move correctly, but in Linuxcnc both in jog and the execution of gcode, the engines are stopped
This is almost always because the drive enable inputs to the stepper drivers are being operated in the inverted sense.
Stepconf does not do anything to enable the drives. It is likely that LinuxCNC is trying to enable the drives but is, in fact, disabling them.
To test this, see if the motors are locked when LinuxCNC is in e-stop mode, and turn freely when LinuxCNC is enabled.
