Rounded corners and "rounded down".
- aparecido
- Thank you received: 6
14 Mar 2016 14:36 #71635
by aparecido
Replied by aparecido on topic Rounded corners and "rounded down".
I tried the two suggestions above, also did not work, now debug returned it (hal file modified attached):
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.4
Machine configuration directory is '/home/aparecido/linuxcnc/configs/cnc3ax'
Machine configuration file is 'cnc3ax.ini'
INIFILE=/home/aparecido/linuxcnc/configs/cnc3ax/cnc3ax.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./cnc3ax.hal
Killing task linuxcncsvr, PID=4056
Debug file information:
./cnc3ax.hal:4: Warning: File contains DOS-style line endings.
HAL: ERROR: function 'sim-hardware.update' not found
./cnc3ax.hal:16: addf failed
4056
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffb0000 (usable)
[ 0.000000] BIOS-e820: 000000007ffb0000 - 000000007ffc0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007ffc0000 - 000000007fff0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fff0000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff780000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: System manufacturer System Product Name/K8V-X SE, BIOS 1015.001 04/20/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7ffb0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FF80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
.......Please Log in or Create an account to join the conversation.
- Thank you received: 4648
14 Mar 2016 14:39 #71636
I am wondering why you have all this simulated hardware stuff.
Probably best to go back to Stepconf and turn of the simulated parallel port and enable the real one.
Replied by andypugh on topic Rounded corners and "rounded down".
The following user(s) said Thank You: aparecido
- aparecido
14 Mar 2016 14:49 #71638
by aparecido
I tried to find where I leave enabled only real parallel port (physical) in stepconf. In which of the screens is this option? Tks
I am wondering why you have all this simulated hardware stuff.HAL: ERROR: function 'sim-hardware.update' not found
14 Mar 2016 15:21 #71642
I think it is on the very first page:
forum.linuxcnc.org/media/kunena/attachments/405/Stepconf.png
- aparecido
14 Mar 2016 16:38 #71645
by aparecido
Resolved, to leave disabled the "Create simulated hardware configuration." and engines properly handled with the 'isplay the Linuxcnc. Thank all a lot for your help.
I think it is on the very first page:I tried to find where I leave enabled only real parallel port (physical) in stepconf. In which of the screens is this option? Tks
Time to create page: 0.124 seconds
