Rounded corners and "rounded down".
10 years 7 months ago - 10 years 7 months ago #71399 by aparecido
Got it, did not get the exits with multimeter, I will do it. Looking at the card scheme in the attached pdf, the jumps are open. The settings are as follows:
Pino 2 X Step
Pino 3 X Direction
Pino 4 Y Step
Pino 5 Y Direction
Pino 6 Z Step
Pino 7 Z Direction
All other pins are as 'unused'.
Just test, the enable pins are connected. In stepconf, pins direction and step change the logical level, but in linuxcnc even in manual / jog, all pins remain at 0V.
I have attached the configuration files.
Last edit: 10 years 7 months ago by aparecido.
10 years 7 months ago - 10 years 7 months ago #71496 by aparecido
I run the program this link wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester and the pins are responding properly, still could not find why the Linuxcnc not move the motors and Stepconf do.
10 years 7 months ago - 10 years 7 months ago #71550 by Rick G
Looks like your config is using sim par port.
# Generated by stepconf 1.1 at Mon Feb 15 03:12:46 2016 # If you make changes to this file, they will be # overwritten when you run stepconf again loadrt trivkins loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt sim_parport names=parport.0 setp parport.0.reset-time 600 loadrt stepgen step_type=0,0,0
linuxcnc.org/docs/html/man/man9/sim_parport.9.html
Rick G
Last edit: 10 years 7 months ago by Rick G.
The following user(s) said Thank You: aparecido
10 years 7 months ago #71586 by aparecido
Thanks for the reply, did not quite understand what it says on the link, so I use the pair port real instead of yes port pair, I just put #, getting "#loadrt sim_parport names = parport.0"? Or should I do something else to use the pair real port?
10 years 7 months ago #71587 by andypugh
A real parallel port would be "loadrt hal_parport ........"
linuxcnc.org/docs/2.7/html/hal/parallel-port.html
10 years 7 months ago #71629 by aparecido
I do not know if I correctly modified the Hal file (I have attached to this post), while trying to run Linuxcnc appears error message and debug content is this:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.4 Machine configuration directory is '/home/aparecido/linuxcnc/configs/cnc3ax' Machine configuration file is 'cnc3ax.ini' INIFILE=/home/aparecido/linuxcnc/configs/cnc3ax/cnc3ax.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI= DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Found file(REL): ./cnc3ax.hal Shutting down and cleaning up LinuxCNC... Killing task linuxcncsvr, PID=4992 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: . ./cnc3ax.hal:7: parameter or pin 'parport.0.reset-time' not found 4992 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffb0000 (usable) [ 0.000000] BIOS-e820: 000000007ffb0000 - 000000007ffc0000 (ACPI data) [ 0.000000] BIOS-e820: 000000007ffc0000 - 000000007fff0000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000007fff0000 - 0000000080000000 (reserved) [ 0.000000] BIOS-e820: 00000000ff780000 - 0000000100000000 (reserved) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: System manufacturer System Product Name/K8V-X SE, BIOS 1015.001 04/20/2006 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0x7ffb0 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-EFFFF uncachable [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 0000000000 mask FF80000000 write-back [ 0.000000] 1 disabled [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [c00ff780] ff780 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 36418000 - 37204000 [ 0.000000] ACPI: RSDP 000fab00 00014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 7ffb0000 00030 (v01 A M I OEMRSDT 04000620 MSFT 00000097) [ 0.000000] ACPI: FACP 7ffb0200 00081 (v01 A M I OEMFACP 04000620 MSFT 00000097) [ 0.000000] ACPI: DSDT 7ffb03e0 03641 (v01 A0232 A0232008 00000008 MSFT 0100000D) [ 0.000000] ACPI: FACS 7ffc0000 00040 [ 0.000000] ACPI: APIC 7ffb0390 0004A (v01 A M I OEMAPIC 04000620 MSFT 00000097) [ 0.000000] ACPI: OEMB 7ffc0040 0003F (v01 A M I OEMBIOS 04000620 MSFT 00000097) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 1159MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x0007ffb0 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x0007ffb0 [ 0.000000] On node 0 totalpages: 524095 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5418200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2320 pages used for memmap [ 0.000000] HighMem zone: 294562 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] Detected use of extended apic ids on hypertransport bus [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7f780000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77e0000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519999 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=760398f5-2d1d-450c-b06d-85702b5cc234 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 4193536 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:0007ffb0) [ 0.000000] Memory: 2054864k/2096832k available (3495k kernel code, 41516k reserved, 1237k data, 416k init, 1187528k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:256 16 [ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] spurious 8259A interrupt: IRQ7. [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] Fast TSC calibration failed [ 0.000000] TSC: PIT calibration matches PMTIMER. 1 loops [ 0.000000] Detected 1600.054 MHz processor. [ 0.012004] Calibrating delay loop (skipped), value calculated using timer frequency.. 3200.10 BogoMIPS (lpj=6400216) [ 0.012012] pid_max: default: 32768 minimum: 301 [ 0.012086] Security Framework initialized [ 0.012098] AppArmor: AppArmor disabled by boot time parameter [ 0.012123] Mount-cache hash table entries: 512 [ 0.012430] Initializing cgroup subsys cpuacct [ 0.012436] Initializing cgroup subsys memory [ 0.012448] Initializing cgroup subsys devices [ 0.012452] Initializing cgroup subsys freezer [ 0.012455] Initializing cgroup subsys net_cls [ 0.012458] Initializing cgroup subsys blkio [ 0.012467] Initializing cgroup subsys perf_event [ 0.012508] mce: CPU supports 5 MCE banks [ 0.012599] SMP alternatives: switching to UP code [ 0.017461] Freeing SMP alternatives: 16k freed [ 0.017478] ACPI: Core revision 20120320 [ 0.020121] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.021185] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0 [ 0.061088] CPU0: AMD Sempron(tm) Processor 2600+ stepping 02 [ 0.064003] Performance Events: AMD PMU driver. [ 0.064003] ... version: 0 [ 0.064003] ... bit width: 48 [ 0.064003] ... generic registers: 4 [ 0.064003] ... value mask: 0000ffffffffffff [ 0.064003] ... max period: 00007fffffffffff [ 0.064003] ... fixed-purpose events: 0 [ 0.064003] ... event mask: 000000000000000f [ 0.072038] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.072086] Brought up 1 CPUs [ 0.072090] Total of 1 processors activated (3200.10 BogoMIPS). [ 0.072762] devtmpfs: initialized [ 0.073103] PM: Registering ACPI NVS region [mem 0x7ffc0000-0x7ffeffff] (196608 bytes) [ 0.073270] dummy: [ 0.073357] NET: Registered protocol family 16 [ 0.073500] node 0 link 0: io port [1000, ffffff] [ 0.073506] TOM: 0000000080000000 aka 2048M [ 0.073512] node 0 link 0: mmio [a0000, bffff] [ 0.073518] node 0 link 0: mmio [80000000, ffffffff] [ 0.073522] bus: [00, ff] on node 0 link 0 [ 0.073527] bus: 00 index 0 [io 0x0000-0xffff] [ 0.073530] bus: 00 index 1 [mem 0x000a0000-0x000bffff] [ 0.073534] bus: 00 index 2 [mem 0x80000000-0xffffffff] [ 0.073579] ACPI: bus type pci registered [ 0.074474] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=1 [ 0.074477] PCI: Using configuration type 1 for base access [ 0.075442] bio: create slab <bio-0> at 0 [ 0.075583] ACPI: Added _OSI(Module Device) [ 0.075587] ACPI: Added _OSI(Processor Device) [ 0.075590] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.075594] ACPI: Added _OSI(Processor Aggregator Device) [ 0.076705] ACPI: EC: Look up EC in DSDT [ 0.078231] ACPI: Executed 1 blocks of module-level executable AML code [ 0.081476] ACPI: Interpreter enabled [ 0.081492] ACPI: (supports S0 S1 S3 S4 S5) [ 0.081529] ACPI: Using IOAPIC for interrupt routing [ 0.089323] ACPI: No dock devices found. [ 0.089337] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug [ 0.089456] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.089622] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored) [ 0.089626] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored) [ 0.089630] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored) [ 0.089635] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xffffffff] (ignored) [ 0.089640] PCI: root bus 00: hardware-probed resources [ 0.089701] PCI host bridge to bus 0000:00 [ 0.089706] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 0.089710] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.089714] pci_bus 0000:00: root bus resource [mem 0x80000000-0xffffffff] [ 0.089744] pci 0000:00:00.0: [1106:0282] type 00 class 0x060000 [ 0.089759] pci 0000:00:00.0: reg 10: [mem 0xec000000-0xefffffff pref] [ 0.089835] pci 0000:00:00.1: [1106:1282] type 00 class 0x060000 [ 0.089882] pci 0000:00:00.2: [1106:2282] type 00 class 0x060000 [ 0.089927] pci 0000:00:00.3: [1106:3282] type 00 class 0x060000 [ 0.089974] pci 0000:00:00.4: [1106:4282] type 00 class 0x060000 [ 0.090021] pci 0000:00:00.7: [1106:7282] type 00 class 0x060000 [ 0.090069] pci 0000:00:01.0: [1106:b188] type 01 class 0x060400 [ 0.090113] pci 0000:00:01.0: supports D1 [ 0.090150] pci 0000:00:0f.0: [1106:3149] type 00 class 0x010400 [ 0.090169] pci 0000:00:0f.0: reg 10: [io 0xe800-0xe807] [ 0.090180] pci 0000:00:0f.0: reg 14: [io 0xe400-0xe403] [ 0.090192] pci 0000:00:0f.0: reg 18: [io 0xe000-0xe007] [ 0.090203] pci 0000:00:0f.0: reg 1c: [io 0xd800-0xd803] [ 0.090214] pci 0000:00:0f.0: reg 20: [io 0xd400-0xd40f] [ 0.090226] pci 0000:00:0f.0: reg 24: [io 0xd000-0xd0ff] [ 0.090274] pci 0000:00:0f.1: [1106:0571] type 00 class 0x01018a [ 0.090324] pci 0000:00:0f.1: reg 20: [io 0xfc00-0xfc0f] [ 0.090388] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300 [ 0.090432] pci 0000:00:10.0: reg 20: [io 0xb800-0xb81f] [ 0.090465] pci 0000:00:10.0: supports D1 D2 [ 0.090469] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.090492] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300 [ 0.090536] pci 0000:00:10.1: reg 20: [io 0xc000-0xc01f] [ 0.090569] pci 0000:00:10.1: supports D1 D2 [ 0.090572] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold [ 0.090594] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300 [ 0.090638] pci 0000:00:10.2: reg 20: [io 0xc400-0xc41f] [ 0.090671] pci 0000:00:10.2: supports D1 D2 [ 0.090674] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold [ 0.090697] pci 0000:00:10.3: [1106:3038] type 00 class 0x0c0300 [ 0.090741] pci 0000:00:10.3: reg 20: [io 0xc800-0xc81f] [ 0.090774] pci 0000:00:10.3: supports D1 D2 [ 0.090777] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold [ 0.090799] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320 [ 0.090816] pci 0000:00:10.4: reg 10: [mem 0xfad00000-0xfad000ff] [ 0.090877] pci 0000:00:10.4: supports D1 D2 [ 0.090880] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold [ 0.090907] pci 0000:00:11.0: [1106:3227] type 00 class 0x060100 [ 0.090973] HPET not enabled in BIOS. You might try hpet=force boot option [ 0.090981] pci 0000:00:11.0: Enabled onboard AC97/MC97 devices [ 0.091025] pci 0000:00:11.5: [1106:3059] type 00 class 0x040100 [ 0.091044] pci 0000:00:11.5: reg 10: [io 0xb400-0xb4ff] [ 0.091113] pci 0000:00:11.5: supports D1 D2 [ 0.091135] pci 0000:00:11.6: [1106:3068] type 00 class 0x078000 [ 0.091154] pci 0000:00:11.6: reg 10: [io 0x0000-0x00ff] [ 0.091241] pci 0000:00:12.0: [1106:3065] type 00 class 0x020000 [ 0.091260] pci 0000:00:12.0: reg 10: [io 0xb000-0xb0ff] [ 0.091271] pci 0000:00:12.0: reg 14: [mem 0xfac00000-0xfac000ff] [ 0.091332] pci 0000:00:12.0: supports D1 D2 [ 0.091335] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.091361] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000 [ 0.091391] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000 [ 0.091417] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000 [ 0.091441] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000 [ 0.091505] pci 0000:01:00.0: [10de:0322] type 00 class 0x030000 [ 0.091520] pci 0000:01:00.0: reg 10: [mem 0xfb000000-0xfbffffff] [ 0.091529] pci 0000:01:00.0: reg 14: [mem 0xf0000000-0xf7ffffff pref] [ 0.091556] pci 0000:01:00.0: reg 30: [mem 0xfaf00000-0xfaf1ffff pref] [ 0.091604] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.091612] pci 0000:00:01.0: bridge window [mem 0xfaf00000-0xfbffffff] [ 0.091619] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf9ffffff pref] [ 0.091628] pci_bus 0000:00: on NUMA node 0 [ 0.091634] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.092061] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e) [ 0.101203] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 *11 14 15) [ 0.101283] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 *10 11 14 15) [ 0.101354] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 7 10 11 14 15) [ 0.101424] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 14 15) *0, disabled. [ 0.101497] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 14 15) *0, disabled. [ 0.101569] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 14 15) *0, disabled. [ 0.101644] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 14 15) *0, disabled. [ 0.101716] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 14 15) *0, disabled. [ 0.101907] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.101911] vgaarb: loaded [ 0.101914] vgaarb: bridge control possible 0000:01:00.0 [ 0.101965] PCI: Using ACPI for IRQ routing [ 0.101971] PCI: pci_cache_line_size set to 64 bytes [ 0.102066] reserve RAM buffer: 000000000009fc00 - 000000000009ffff [ 0.102070] reserve RAM buffer: 000000007ffb0000 - 000000007fffffff [ 0.102422] pnp: PnP ACPI init [ 0.102442] ACPI: bus type pnp registered [ 0.102606] pnp 00:00: [bus 00-ff] [ 0.102610] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.102615] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.102618] pnp 00:00: [io 0x0d00-0xffff window] [ 0.102622] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.102626] pnp 00:00: [mem 0x00000000 window] [ 0.102630] pnp 00:00: [mem 0x80000000-0xffffffff window] [ 0.102707] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active) [ 0.102753] pnp 00:01: [dma 4] [ 0.102756] pnp 00:01: [io 0x0000-0x000f] [ 0.102760] pnp 00:01: [io 0x0081-0x0083] [ 0.102763] pnp 00:01: [io 0x0087] [ 0.102766] pnp 00:01: [io 0x0089-0x008b] [ 0.102769] pnp 00:01: [io 0x008f] [ 0.102773] pnp 00:01: [io 0x00c0-0x00df] [ 0.102807] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.102826] pnp 00:02: [io 0x0070-0x0071] [ 0.102846] pnp 00:02: [irq 8] [ 0.102883] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.102928] pnp 00:03: [io 0x0060] [ 0.102932] pnp 00:03: [io 0x0064] [ 0.102940] pnp 00:03: [irq 1] [ 0.102983] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 PNP030b (active) [ 0.103050] pnp 00:04: [irq 12] [ 0.103096] pnp 00:04: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active) [ 0.103110] pnp 00:05: [io 0x0061] [ 0.103146] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.103162] pnp 00:06: [io 0x00f0-0x00ff] [ 0.103169] pnp 00:06: [irq 13] [ 0.103205] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.103648] pnp 00:07: [irq 6] [ 0.103652] pnp 00:07: [dma 2] [ 0.103656] pnp 00:07: [io 0x03f0-0x03f5] [ 0.103659] pnp 00:07: [io 0x03f7] [ 0.103740] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.104181] pnp 00:08: [io 0x0378-0x037f] [ 0.104190] pnp 00:08: [irq 7] [ 0.104389] pnp 00:08: Plug and Play ACPI device, IDs PNP0400 (active) [ 0.104436] pnp 00:09: [io 0x0000-0xffffffff disabled] [ 0.104440] pnp 00:09: [io 0x0000-0xffffffff disabled] [ 0.104444] pnp 00:09: [io 0x0290-0x0297] [ 0.104530] system 00:09: [io 0x0290-0x0297] has been reserved [ 0.104535] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.104660] pnp 00:0a: [io 0x0010-0x001f] [ 0.104667] pnp 00:0a: [io 0x0022-0x003f] [ 0.104671] pnp 00:0a: [io 0x0044-0x005f] [ 0.104675] pnp 00:0a: [io 0x0062-0x0063] [ 0.104678] pnp 00:0a: [io 0x0065-0x006f] [ 0.104681] pnp 00:0a: [io 0x0072-0x007f] [ 0.104685] pnp 00:0a: [io 0x0080] [ 0.104688] pnp 00:0a: [io 0x0084-0x0086] [ 0.104691] pnp 00:0a: [io 0x0088] [ 0.104695] pnp 00:0a: [io 0x008c-0x008e] [ 0.104698] pnp 00:0a: [io 0x0090-0x009f] [ 0.104701] pnp 00:0a: [io 0x00a2-0x00bf] [ 0.104705] pnp 00:0a: [io 0x00e0-0x00ef] [ 0.104708] pnp 00:0a: [io 0x03e1-0x03e7] [ 0.104712] pnp 00:0a: [io 0x04d0-0x04d1] [ 0.104715] pnp 00:0a: [io 0x0800-0x087f] [ 0.104718] pnp 00:0a: [io 0x0400-0x041f] [ 0.104722] pnp 00:0a: [io 0x0000-0xffffffff disabled] [ 0.104759] pnp 00:0a: disabling [io 0x0010-0x001f] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104765] pnp 00:0a: disabling [io 0x0022-0x003f] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104770] pnp 00:0a: disabling [io 0x0044-0x005f] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104775] pnp 00:0a: disabling [io 0x0062-0x0063] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104781] pnp 00:0a: disabling [io 0x0065-0x006f] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104786] pnp 00:0a: disabling [io 0x0072-0x007f] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104791] pnp 00:0a: disabling [io 0x0080] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104796] pnp 00:0a: disabling [io 0x0084-0x0086] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104801] pnp 00:0a: disabling [io 0x0088] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104806] pnp 00:0a: disabling [io 0x008c-0x008e] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104812] pnp 00:0a: disabling [io 0x0090-0x009f] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104817] pnp 00:0a: disabling [io 0x00a2-0x00bf] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104822] pnp 00:0a: disabling [io 0x00e0-0x00ef] because it overlaps 0000:00:11.6 BAR 0 [io 0x0000-0x00ff] [ 0.104873] system 00:0a: [io 0x03e1-0x03e7] has been reserved [ 0.104878] system 00:0a: [io 0x04d0-0x04d1] has been reserved [ 0.104883] system 00:0a: [io 0x0800-0x087f] has been reserved [ 0.104887] system 00:0a: [io 0x0400-0x041f] has been reserved [ 0.104892] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.104993] pnp 00:0b: [mem 0xfec00000-0xfec00fff] [ 0.104997] pnp 00:0b: [mem 0xfee00000-0xfee00fff] [ 0.105001] pnp 00:0b: [mem 0xfff80000-0xffffffff] [ 0.105062] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.105068] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.105075] system 00:0b: [mem 0xfff80000-0xffffffff] has been reserved [ 0.105080] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.105473] pnp 00:0c: [io 0x03f8-0x03ff] [ 0.105488] pnp 00:0c: [irq 4] [ 0.105581] pnp 00:0c: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.105765] pnp 00:0d: [mem 0x00000000-0x0009ffff] [ 0.105770] pnp 00:0d: [mem 0x000c0000-0x000dffff] [ 0.105774] pnp 00:0d: [mem 0x000e0000-0x000fffff] [ 0.105777] pnp 00:0d: [mem 0x00100000-0x7ffeffff] [ 0.105781] pnp 00:0d: [mem 0x00000000-0xffffffff disabled] [ 0.105867] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.105872] system 00:0d: [mem 0x000c0000-0x000dffff] could not be reserved [ 0.105877] system 00:0d: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.105882] system 00:0d: [mem 0x00100000-0x7ffeffff] could not be reserved [ 0.105887] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.106093] pnp: PnP ACPI: found 14 devices [ 0.106096] ACPI: ACPI bus type pnp unregistered [ 0.106102] PnPBIOS: Disabled by ACPI PNP [ 0.143135] Switching to clocksource acpi_pm [ 0.143222] pci 0000:00:11.6: BAR 0: assigned [io 0x1000-0x10ff] [ 0.143232] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.143240] pci 0000:00:01.0: bridge window [mem 0xfaf00000-0xfbffffff] [ 0.143246] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf9ffffff pref] [ 0.143269] pci 0000:00:01.0: setting latency timer to 64 [ 0.143275] pci_bus 0000:00: resource 4 [io 0x0000-0xffff] [ 0.143279] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff] [ 0.143283] pci_bus 0000:00: resource 6 [mem 0x80000000-0xffffffff] [ 0.143287] pci_bus 0000:01: resource 1 [mem 0xfaf00000-0xfbffffff] [ 0.143291] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf9ffffff pref] [ 0.143410] NET: Registered protocol family 2 [ 0.143514] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.143906] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.143906] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.143906] TCP: Hash tables configured (established 131072 bind 65536) [ 0.143906] TCP: reno registered [ 0.143906] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.143906] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.143906] NET: Registered protocol family 1 [ 0.143906] pci 0000:00:01.0: disabling DAC on VIA PCI bridge [ 1.744018] pci 0000:00:10.4: EHCI: BIOS handoff failed (BIOS bug?) 01010001 [ 1.744162] pci 0000:01:00.0: Boot video device [ 1.744167] PCI: CLS 64 bytes, default 64 [ 1.744254] Unpacking initramfs... [ 2.228102] Freeing initrd memory: 14256k freed [ 2.248956] audit: initializing netlink socket (disabled) [ 2.248984] type=2000 audit(1455517278.247:1): initialized [ 2.267644] highmem bounce pool size: 64 pages [ 2.267654] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 2.267857] VFS: Disk quotas dquot_6.5.2 [ 2.267894] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 2.268039] msgmni has been set to 1721 [ 2.268297] alg: No test for stdrng (krng) [ 2.268351] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 2.268357] io scheduler noop registered [ 2.268360] io scheduler deadline registered [ 2.268379] io scheduler cfq registered (default) [ 2.268538] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 2.268568] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 2.268571] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 2.269005] GHES: HEST is not enabled! [ 2.269023] isapnp: Scanning for PnP cards... [ 2.622837] isapnp: No Plug & Play device found [ 2.622931] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 2.643250] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 2.663921] 00:0c: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 2.664193] Linux agpgart interface v0.103 [ 2.664264] agpgart-amd64 0000:00:00.0: AGP bridge [1106/0282] [ 2.664274] agpgart-amd64 0000:00:00.0: aperture from AGP @ ec000000 size 64 MB [ 2.666822] agpgart-amd64 0000:00:00.0: AGP aperture is 64M @ 0xec000000 [ 2.667074] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12 [ 2.667623] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 2.667670] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 2.667802] mousedev: PS/2 mouse device common for all mice [ 2.667870] rtc_cmos 00:02: RTC can wake from S4 [ 2.668127] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0 [ 2.668186] rtc0: alarms up to one year, y3k, 114 bytes nvram [ 2.668393] TCP: cubic registered [ 2.668452] NET: Registered protocol family 10 [ 2.668764] Mobile IPv6 [ 2.668771] NET: Registered protocol family 17 [ 2.668778] Registering the dns_resolver key type [ 2.668863] Using IPI No-Shortcut mode [ 2.669032] PM: Hibernation image not present or could not be loaded. [ 2.669055] registered taskstats version 1 [ 2.669537] rtc_cmos 00:02: setting system clock to 2016-02-15 06:21:19 UTC (1455517279) [ 2.669689] Freeing unused kernel memory: 416k freed [ 2.670319] Write protecting the kernel text: 3496k [ 2.670351] Write protecting the kernel read-only data: 984k [ 2.687057] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 2.700405] udevd[45]: starting version 175 [ 2.876926] Floppy drive(s): fd0 is 1.44M [ 2.878201] SCSI subsystem initialized [ 2.896116] FDC 0 is a post-1991 82077 [ 2.899630] usbcore: registered new interface driver usbfs [ 2.899670] usbcore: registered new interface driver hub [ 2.905474] usbcore: registered new device driver usb [ 2.917700] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.917814] ehci_hcd 0000:00:10.4: EHCI Host Controller [ 2.917866] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1 [ 2.917954] ehci_hcd 0000:00:10.4: irq 21, io mem 0xfad00000 [ 2.920096] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker [ 2.923115] uhci_hcd: USB Universal Host Controller Interface driver [ 2.927767] libata version 3.00 loaded. [ 2.928064] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00 [ 2.928148] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.928153] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.928157] usb usb1: Product: EHCI Host Controller [ 2.928161] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 2.928165] usb usb1: SerialNumber: 0000:00:10.4 [ 2.928376] hub 1-0:1.0: USB hub found [ 2.928384] hub 1-0:1.0: 8 ports detected [ 2.929908] via-rhine 0000:00:12.0: eth0: VIA Rhine II at 0x1b000, 00:15:f2:cf:ba:3f, IRQ 23 [ 2.930689] via-rhine 0000:00:12.0: eth0: MII PHY found at address 1, status 0x7849 advertising 01e1 Link 0000 [ 2.931561] sata_via 0000:00:0f.0: version 2.6 [ 2.931672] sata_via 0000:00:0f.0: routed to hard irq line 10 [ 2.935678] scsi0 : sata_via [ 2.939116] scsi1 : sata_via [ 2.939217] ata1: SATA max UDMA/133 cmd 0xe800 ctl 0xe400 bmdma 0xd400 irq 20 [ 2.939222] ata2: SATA max UDMA/133 cmd 0xe000 ctl 0xd800 bmdma 0xd408 irq 20 [ 2.939401] uhci_hcd 0000:00:10.0: UHCI Host Controller [ 2.939430] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2 [ 2.939467] uhci_hcd 0000:00:10.0: irq 21, io base 0x0000b800 [ 2.939534] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.939539] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.939543] usb usb2: Product: UHCI Host Controller [ 2.939546] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 2.939550] usb usb2: SerialNumber: 0000:00:10.0 [ 2.939751] hub 2-0:1.0: USB hub found [ 2.939760] hub 2-0:1.0: 2 ports detected [ 2.939903] uhci_hcd 0000:00:10.1: UHCI Host Controller [ 2.939917] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3 [ 2.939947] uhci_hcd 0000:00:10.1: irq 21, io base 0x0000c000 [ 2.940050] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.940054] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.940058] usb usb3: Product: UHCI Host Controller [ 2.940062] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 2.940066] usb usb3: SerialNumber: 0000:00:10.1 [ 2.940242] hub 3-0:1.0: USB hub found [ 2.940251] hub 3-0:1.0: 2 ports detected [ 2.940367] uhci_hcd 0000:00:10.2: UHCI Host Controller [ 2.940384] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4 [ 2.940415] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000c400 [ 2.940471] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.940475] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.940479] usb usb4: Product: UHCI Host Controller [ 2.940482] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 2.940486] usb usb4: SerialNumber: 0000:00:10.2 [ 2.940653] hub 4-0:1.0: USB hub found [ 2.940661] hub 4-0:1.0: 2 ports detected [ 2.940774] uhci_hcd 0000:00:10.3: UHCI Host Controller [ 2.940785] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5 [ 2.940814] uhci_hcd 0000:00:10.3: irq 21, io base 0x0000c800 [ 2.940872] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.940877] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.940880] usb usb5: Product: UHCI Host Controller [ 2.940884] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 2.940888] usb usb5: SerialNumber: 0000:00:10.3 [ 2.941055] hub 5-0:1.0: USB hub found [ 2.941062] hub 5-0:1.0: 2 ports detected [ 2.941187] pata_via 0000:00:0f.1: version 0.3.4 [ 2.943904] scsi2 : pata_via [ 2.946956] scsi3 : pata_via [ 2.949903] ata3: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14 [ 2.949909] ata4: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15 [ 2.953625] microcode: AMD CPU family 0xf not supported [ 3.112561] ata3.00: ATA-6: Maxtor 4D040H2, DAK019K0, max UDMA/133 [ 3.112570] ata3.00: 80043264 sectors, multi 16: LBA48 [ 3.112578] ata3.00: limited to UDMA/33 due to 40-wire cable [ 3.128443] ata3.00: configured for UDMA/33 [ 3.140026] ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300) [ 3.240025] usb 1-4: new high-speed USB device number 2 using ehci_hcd [ 3.256021] Refined TSC clocksource calibration: 1600.057 MHz. [ 3.256030] Switching to clocksource tsc [ 3.368012] ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300) [ 3.379602] usb 1-4: New USB device found, idVendor=0781, idProduct=5567 [ 3.379606] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.379611] usb 1-4: Product: Cruzer Blade [ 3.379614] usb 1-4: Manufacturer: SanDisk [ 3.379617] usb 1-4: SerialNumber: 4C530599941030117035 [ 3.385268] Initializing USB Mass Storage driver... [ 3.385443] scsi4 : usb-storage 1-4:1.0 [ 3.386070] usbcore: registered new interface driver usb-storage [ 3.386078] USB Mass Storage support registered. [ 3.392199] scsi 2:0:0:0: Direct-Access ATA Maxtor 4D040H2 DAK0 PQ: 0 ANSI: 5 [ 3.591892] sd 2:0:0:0: [sda] 80043264 512-byte logical blocks: (40.9 GB/38.1 GiB) [ 3.591964] sd 2:0:0:0: [sda] Write Protect is off [ 3.591969] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 3.592114] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.635250] sda: sda1 sda2 < sda5 > [ 3.635769] sd 2:0:0:0: [sda] Attached SCSI disk [ 3.639901] sd 2:0:0:0: Attached scsi generic sg0 type 0 [ 4.385237] scsi 4:0:0:0: Direct-Access SanDisk Cruzer Blade 1.26 PQ: 0 ANSI: 6 [ 4.389501] sd 4:0:0:0: Attached scsi generic sg1 type 0 [ 4.390490] sd 4:0:0:0: [sdb] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB) [ 4.391987] sd 4:0:0:0: [sdb] Write Protect is off [ 4.392048] sd 4:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 4.392860] sd 4:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 4.396922] sdb: sdb1 [ 4.399608] sd 4:0:0:0: [sdb] Attached SCSI disk [ 9.166612] microcode: AMD CPU family 0xf not supported [ 9.170850] microcode: AMD CPU family 0xf not supported [ 9.195417] PM: Starting manual resume from disk [ 9.195427] PM: Hibernation image partition 8:5 present [ 9.195430] PM: Looking for hibernation image. [ 9.195852] PM: Image not found (code -22) [ 9.195856] PM: Hibernation image not present or could not be loaded. [ 9.269371] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 11.981876] udevd[332]: starting version 175 [ 12.336083] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1 [ 12.336097] ACPI: Power Button [PWRB] [ 12.338123] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2 [ 12.338136] ACPI: Sleep Button [SLPB] [ 12.338220] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 12.338225] ACPI: Power Button [PWRF] [ 12.440071] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 12.454290] parport_pc 00:08: reported by Plug and Play ACPI [ 12.454321] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP] [ 12.547941] microcode: AMD CPU family 0xf not supported [ 13.244649] [drm] Initialized drm 1.1.0 20060810 [ 13.465194] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4 [ 13.701827] wmi: Mapper loaded [ 13.876803] snd_via82xx_modem 0000:00:11.6: enabling device (0000 -> 0001) [ 14.045557] [drm] nouveau 0000:01:00.0: Detected an NV30 generation card (0x034200b1) [ 14.046800] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS [ 14.093269] [drm] nouveau 0000:01:00.0: ... appears to be valid [ 14.093278] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN [ 14.093534] [drm] nouveau 0000:01:00.0: BMP BIOS found [ 14.093538] [drm] nouveau 0000:01:00.0: BMP version 5.41 [ 14.093543] [drm] nouveau 0000:01:00.0: Bios version 04.34.20.87 [ 14.094212] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do [ 14.094219] [drm] nouveau 0000:01:00.0: DCB version 2.2 [ 14.094225] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000300 000088b8 [ 14.094230] [drm] nouveau 0000:01:00.0: DCB outp 01: 01010312 00008800 [ 14.094234] [drm] nouveau 0000:01:00.0: DCB outp 02: 02020321 00000303 [ 14.094465] [drm] nouveau 0000:01:00.0: Loading NV17 power sequencing microcode [ 14.094471] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xED03 [ 14.096557] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xEF9E [ 14.096569] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xF0E4 [ 14.096610] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xF26D [ 14.096616] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xF28A [ 14.096623] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0xF2A7 [ 14.117563] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0xF440 [ 14.117826] [TTM] Zone kernel: Available graphics memory: 441012 kiB [ 14.117831] [TTM] Zone highmem: Available graphics memory: 1034776 kiB [ 14.117834] [TTM] Initializing pool allocator [ 14.117888] [drm] nouveau 0000:01:00.0: Detected 128MiB VRAM (DDR1) [ 14.118269] agpgart-amd64 0000:00:00.0: AGP 3.0 bridge [ 14.118293] agpgart: modprobe tried to set rate=x12. Setting to AGP3 x8 mode. [ 14.118302] agpgart-amd64 0000:00:00.0: putting AGP V3 device into 8x mode [ 14.118427] nouveau 0000:01:00.0: putting AGP V3 device into 8x mode [ 14.118432] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture) [ 14.118555] [drm] nouveau 0000:01:00.0: Saving VGA fonts [ 14.166550] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 14.166557] [drm] No driver support for vblank timestamp query. [ 14.172161] [drm] nouveau 0000:01:00.0: 0 available performance level(s) [ 14.172168] [drm] nouveau 0000:01:00.0: c: core 249MHz memory 405MHz [ 14.173769] [drm] nouveau 0000:01:00.0: 0xE0DC: Parsing digital output script table [ 14.224317] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 2) [ 14.300779] [drm] nouveau 0000:01:00.0: allocated 1440x900 fb: 0x49000, bo f53d9400 [ 14.301049] fbcon: nouveaufb (fb0) is primary device [ 14.314995] Console: switching to colour frame buffer device 180x56 [ 14.316664] fb0: nouveaufb frame buffer device [ 14.316668] drm: registered panic notifier [ 14.316677] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0 [ 14.632048] snd_via82xx_modem 0000:00:11.6: setting latency timer to 64 [ 15.136259] snd_via82xx_modem: probe of 0000:00:11.6 failed with error -13 [ 15.136912] snd_via82xx 0000:00:11.5: setting latency timer to 64 [ 15.651353] codec_read: codec 0 is not valid [0xfe0000] [ 15.658510] codec_read: codec 0 is not valid [0xfe0000] [ 15.665742] codec_read: codec 0 is not valid [0xfe0000] [ 15.672899] codec_read: codec 0 is not valid [0xfe0000] [ 17.452858] Adding 1670140k swap on /dev/sda5. Priority:-1 extents:1 across:1670140k [ 17.481665] EXT4-fs (sda1): re-mounted. Opts: (null) [ 17.882781] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 18.094602] loop: module loaded [ 20.616091] RPC: Registered named UNIX socket transport module. [ 20.616100] RPC: Registered udp transport module. [ 20.616103] RPC: Registered tcp transport module. [ 20.616106] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 20.658522] FS-Cache: Loaded [ 20.709997] NFS: Registering the id_resolver key type [ 20.710044] FS-Cache: Netfs 'nfs' registered for caching [ 20.725216] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 23.405885] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5 [ 25.288898] Bluetooth: Core ver 2.16 [ 25.289465] NET: Registered protocol family 31 [ 25.289472] Bluetooth: HCI device and connection manager initialized [ 25.289478] Bluetooth: HCI socket layer initialized [ 25.289481] Bluetooth: L2CAP socket layer initialized [ 25.289493] Bluetooth: SCO socket layer initialized [ 25.334618] Bluetooth: RFCOMM TTY layer initialized [ 25.334629] Bluetooth: RFCOMM socket layer initialized [ 25.334633] Bluetooth: RFCOMM ver 1.11 [ 25.406128] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 25.406136] Bluetooth: BNEP filters: protocol multicast [ 25.526675] lp0: using parport0 (interrupt-driven). [ 25.657526] ppdev: user-space parallel port driver [ 30.277444] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 60.789332] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 84.677553] I-pipe: head domain RTAI registered. [ 84.677569] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 84.677579] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 84.677585] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 84.677589] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 84.677594] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12414750 [ 84.779016] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 84.779113] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 84.779119] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 84.779125] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 84.779129] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 84.811565] RTAI[math]: loaded. [ 88.069484] RTAI[math]: unloaded. [ 88.073698] SCHED releases registered named ALIEN PEDV$D [ 88.082805] RTAI[malloc]: unloaded. [ 88.180019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 88.183922] I-pipe: head domain RTAI unregistered. [ 88.183943] RTAI[hal]: unmounted. [ 161.484806] I-pipe: head domain RTAI registered. [ 161.484822] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 161.484832] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 161.484838] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 161.484842] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 161.484848] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12403000 [ 161.505372] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 161.505469] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 161.505476] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 161.505481] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 161.505485] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 161.526354] RTAI[math]: loaded. [ 164.339078] RTAI[math]: unloaded. [ 164.343189] SCHED releases registered named ALIEN PEDV$D [ 164.352356] RTAI[malloc]: unloaded. [ 164.455668] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 164.460248] I-pipe: head domain RTAI unregistered. [ 164.460267] RTAI[hal]: unmounted. [ 349.600349] I-pipe: head domain RTAI registered. [ 349.600362] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 349.600372] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 349.600377] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 349.600382] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 349.600387] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12363250 [ 349.621153] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 349.621251] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 349.621257] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 349.621262] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 349.621266] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 349.641486] RTAI[math]: loaded. [ 360.597674] RTAI[math]: unloaded. [ 360.606571] SCHED releases registered named ALIEN PEDV$D [ 360.625080] RTAI[malloc]: unloaded. [ 360.724032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 360.729106] I-pipe: head domain RTAI unregistered. [ 360.729125] RTAI[hal]: unmounted. [ 460.783811] I-pipe: head domain RTAI registered. [ 460.783826] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 460.783836] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 460.783842] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 460.783846] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 460.783851] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12391000 [ 460.807379] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 460.807480] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 460.807486] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 460.807492] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 460.807495] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 460.823395] RTAI[math]: loaded. [ 461.058877] config string '0x378 in' [ 463.715779] RTAI[math]: unloaded. [ 463.719979] SCHED releases registered named ALIEN PEDV$D [ 463.730769] RTAI[malloc]: unloaded. [ 463.828031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 463.831889] I-pipe: head domain RTAI unregistered. [ 463.831910] RTAI[hal]: unmounted. [ 475.095599] I-pipe: head domain RTAI registered. [ 475.095614] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 475.095625] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 475.095630] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 475.095635] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 475.095640] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12384500 [ 475.112976] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 475.113073] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 475.113080] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 475.113085] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 475.113089] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 475.127397] RTAI[math]: loaded. [ 475.317755] config string '0x378' [ 477.942838] RTAI[math]: unloaded. [ 477.947000] SCHED releases registered named ALIEN PEDV$D [ 477.955256] RTAI[malloc]: unloaded. [ 478.052118] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 478.055978] I-pipe: head domain RTAI unregistered. [ 478.056246] RTAI[hal]: unmounted. [ 510.543945] I-pipe: head domain RTAI registered. [ 510.543960] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 510.543971] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 510.543977] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 510.543981] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 510.543991] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12390000 [ 510.567301] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 510.567405] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 510.567411] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 510.567417] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 510.567420] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 510.590594] RTAI[math]: loaded. [ 513.434766] RTAI[math]: unloaded. [ 513.438881] SCHED releases registered named ALIEN PEDV$D [ 513.447392] RTAI[malloc]: unloaded. [ 513.544032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 513.547961] I-pipe: head domain RTAI unregistered. [ 513.548858] RTAI[hal]: unmounted. [ 593.918287] I-pipe: head domain RTAI registered. [ 593.918303] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 593.918313] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 593.918318] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 593.918323] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 593.918328] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12402250 [ 593.938674] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 593.938772] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 593.938778] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 593.938784] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 593.938787] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 593.958080] RTAI[math]: loaded. [ 596.802099] RTAI[math]: unloaded. [ 596.806262] SCHED releases registered named ALIEN PEDV$D [ 596.815301] RTAI[malloc]: unloaded. [ 596.912027] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 596.915890] I-pipe: head domain RTAI unregistered. [ 596.915910] RTAI[hal]: unmounted. [ 611.169880] I-pipe: head domain RTAI registered. [ 611.169895] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 611.169906] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 611.169911] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 611.169916] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 611.169921] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12418250 [ 611.189683] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 611.189785] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 611.189791] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 611.189797] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 611.189801] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 611.213609] RTAI[math]: loaded. [ 614.043009] RTAI[math]: unloaded. [ 614.047114] SCHED releases registered named ALIEN PEDV$D [ 614.055509] RTAI[malloc]: unloaded. [ 614.152032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 614.155967] I-pipe: head domain RTAI unregistered. [ 614.155987] RTAI[hal]: unmounted. [ 637.451282] I-pipe: head domain RTAI registered. [ 637.451297] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 637.451308] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 637.451313] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 637.451318] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 637.458542] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12404500 [ 637.476192] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 637.476284] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 637.476290] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 637.476296] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 637.476299] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 637.491991] RTAI[math]: loaded. [ 640.295185] RTAI[math]: unloaded. [ 640.299352] SCHED releases registered named ALIEN PEDV$D [ 640.308203] RTAI[malloc]: unloaded. [ 640.408029] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 640.411908] I-pipe: head domain RTAI unregistered. [ 640.411929] RTAI[hal]: unmounted. [ 682.704207] I-pipe: head domain RTAI registered. [ 682.704220] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 682.704230] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 682.704236] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12500398, CLK_FREQ 1600054000, CPU_FREQ 1600054000 [ 682.704241] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 682.704246] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12500398, 12500398, 12396500 [ 682.724184] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 682.724276] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 682.724283] RTAI[sched]: hard timer type/freq = APIC/12500398(Hz); default timing: oneshot; linear timed lists. [ 682.724288] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1600054000 hz. [ 682.724292] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 682.745476] RTAI[math]: loaded. [ 685.544624] RTAI[math]: unloaded. [ 685.548801] SCHED releases registered named ALIEN PEDV$D [ 685.557229] RTAI[malloc]: unloaded. [ 685.656029] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 685.659910] I-pipe: head domain RTAI unregistered. [ 685.659930] RTAI[hal]: unmounted.
Time to create page: 0.185 seconds
