Matsuura Mc 500v2 retrofit.
10 years 5 months ago #74580 by skunkworks
working my way through the tool change logic..
sam
10 years 5 months ago #74585 by emcPT
Replied by emcPT on topic Matsuura Mc 500v2 retrofit.
Hello,
What do you use to label your wires? It is retractable tube with printed labels? If so, how do you do it?
That machine is quite a good machine. Congratulations.
10 years 5 months ago #74604 by skunkworks
A brother label writer.. It isn't the best - The clear coat seems to like to peal off after a while. On the K&T we used electrical numbering stickers and then clear heat shrink over that. That worked the best IMHO.
sam
10 years 5 months ago #74633 by skunkworks
simple program with rigid tapping. (didn't have time to try it in metal)
10 years 5 months ago #74643 by BigJohnT
emcPT wrote: Hello,
I use Brady heat shrink labels and they are permanent as I am.
JT
10 years 4 months ago #76815 by skunkworks
The spindle taper has 30 years of wear - a 6 inch tool was around .006" out. So - we didn't have much to lose ;)
Now it is around .0005" at 6 inches.
(the dremel was the only thing that would fit up the BT35 taper) - that we had anyway
We also took added about .0015 shim between the 2 ball nuts on the Z axis.
electronicsam.com/images/matsuura/20160608_185327.jpg
Control panel
electronicsam.com/images/matsuura/20160622_153043.jpg
Time to create page: 0.398 seconds
