Matsuura Mc 500v2 retrofit.
10 years 3 months ago #77391 by skunkworks
Almost done... maybe 90%. Still need some i/o hooked up for over-currents and lube level. Some tweeking of the tool change so that it can fail gracefully.
sam
10 years 3 months ago #77392 by BigJohnT
Looking Good!
JT
10 years 1 month ago #81111 by eman5oh
Replied by eman5oh on topic Matsuura Mc 500v2 retrofit.
I see you did a spindle regrind, how did you align the Dremel to the taper?
10 years 1 month ago - 10 years 1 month ago #81115 by skunkworks
really no alignment other than making sure it clears the whole way in.. The matsuura was doing the taper by moving z and y coordinated.
edit - after that we blued it to check fit. Looked good.
sam
Last edit: 10 years 1 month ago by skunkworks.
9 years 11 months ago #82857 by johnmc
Replied by johnmc on topic Matsuura Mc 500v2 retrofit.
Good Day ,Sam
Your matsuura is looking neat, is the monitor a touch screen, where did you fit the pc ?, on the console is that a mpg for each axis?, has the Ethernet has been difficult to implement?. pardon the many
I have a matsuura with brain dead fanuc m6 control and your machine setup really looks the answer.
johnmc
9 years 9 months ago #85500 by chopper79
Nice job on the retrofit. I am going to begin mine in the next week or so. I have a 1982 MC-500v showing up Tuesday of this month. The MX1 controller will not function properly so retrofit it will be.
I will start a new thread, but wanted to let you know that I like what you have done.
Time to create page: 0.498 seconds
