MPG causing axis oscillations.
30 Mar 2016 13:29 #72388 by eman5oh
MPG causing axis oscillations. was created by eman5oh
I finally have my machine fully configured and everything working as it should except for my MPG pendant. Sometimes but not all the time when I jog the machine with the mpg the axis I am jogging oscillates at the end of the move. It acts like a servo motor with too much P gain. I am running stepper motors on my machine with a MESA 5i25 connected to a 7i76 card. The machine moves fine when jogging with the keyboard and I ran the 3d tux file several times with no issues. As I was setting up the machine the following error was set .500 in and now is set to .010. With .010 I get a small oscillation then the axis will fault with a following error. I have tried the MPG with and without debounce with the same result. I have also tried the standard jog mode and velocity mode. It still happens on occasion. I am running 2.7.4 and have tried the 2.7.4 with build bot fixes. What should I be looking for to track this down?
30 Mar 2016 14:36 - 30 Mar 2016 15:46 #72389 by PCW
Replied by PCW on topic MPG causing axis oscillations.
It would help to have the .ini file included as this has all the parameters
This sounds like a tuning issue of some kind so the parameters are needed to
discover what's wrong
in general I do know that larger jog increments can cause troubles and this is often fixed by
running the jog signal through the ilowpass component
Last edit: 30 Mar 2016 15:46 by PCW.
30 Mar 2016 16:26 - 30 Mar 2016 16:28 #72391 by eman5oh
Replied by eman5oh on topic MPG causing axis oscillations.
ini file below
I will try to use the ilowpass and see if it fixes this.
Last edit: 30 Mar 2016 16:28 by eman5oh.
30 Mar 2016 17:06 #72399 by PCW
Jog inputs should not violate acceleration and velocity constraints
but it does seem like this is happening.
The filter should help (and make larger jog increments a lot more pleasant)
but it still does not explain why you are getting this violation
one thing I am suspicious of is the trajectory planner not running
at the servo thread rate so you might try changing the TRAJ
cycle time to match:
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.001 -- changed from .010
DEFAULT_VELOCITY = 0.17
MAX_LINEAR_VELOCITY = 1.67
30 Mar 2016 17:38 #72405 by eman5oh
Thanks for the help, I will try both and report back.
31 Mar 2016 01:08 #72429 by eman5oh
I tried both of your suggestions and I still the issue, if I set ilowpass.0.gain to .5 the osilatiosn stop but I get the axis fault with following error. I seems to only happen when I have the jog incement set to .100 in per click and turn the mpg slowly. Any more ideas?
31 Mar 2016 01:31 #72430 by PCW
0.5 is way too high (1/2 in 1 ms, 3/4 in 2 ms etc)
I would try .005 or so as a start
The following user(s) said Thank You: eman5oh
31 Mar 2016 01:53 #72431 by eman5oh
I found .050 seems to be what the machine likes. This is a lot better than it was but it still oscillates a little form time to time while jogging. I have the following error set to .010 is that a reasonable setting for steppers?
31 Mar 2016 02:00 #72433 by PCW
Thats still pretty high, why not lower?
( the example here suggests 0.01 )
linuxcnc.org/docs/html/examples/mpg.html
(scroll down to "jog.hal with ilowpass" )
what is the ilowpass scale?
I have 0.0001, 0.0002 as FE setting on a 1G accel/2400 IPM test config
31 Mar 2016 17:16 #72483 by eman5oh
I tried .01 and lower but it seems to make the oscillations worse, .05 was the result of tring a bunch of different settings and seeing what worked best. It seems lowpass masks the problem but does not make it go away. I will try to lower the ferror to .001 and do some more testing. ilowpass scale is set to 1 so my jog steps are .001, .010, and .100 per click of the mpg.
Time to create page: 0.103 seconds
