MPG causing axis oscillations.
04 Apr 2016 12:11 #72704 by eman5oh
Replied by eman5oh on topic MPG causing axis oscillations.
The issue has crept back up as I go through commissioning my machine. I turned on backlash comp and I occasionally get following errors while mpg jogging again. I had to raise the following error or I could not home the machine , it would give a following error during the homing sequence.
04 Apr 2016 14:25 #72718 by PCW
Replied by PCW on topic MPG causing axis oscillations.
This is not unexpected as you need to double the stepgens maxaccel value
if backlash compensation is used ( this applies to all step/dir linuxcnc systems )
04 Apr 2016 14:44 #72720 by eman5oh
Ok will try this, they were 25% higher as per the note in the generated ini file. I will up them to double.
04 Apr 2016 14:50 #72722 by PCW
I meant double their current value (so 250% of machine accel value)
04 Apr 2016 14:57 #72723 by eman5oh
So that I am clear, if my machine is set to 10 units of accel normally the max accel should be 25 units?
04 Apr 2016 16:11 #72727 by PCW
Yes, 25, because the trajectory planner uses double the machines per axis acceleration limits when
performing backlash compensation so 2 x1.25 = 250%
The following user(s) said Thank You: eman5oh
Time to create page: 0.311 seconds
