Mazak M4 Lathe
- P.I.H
19 Apr 2016 07:09 #73583
by P.I.H
Mazak M4 Lathe was created by P.I.H
I have a Mazak M4 Lathe.
It has 16 chips on the PCB controller and as I understand it the parts are no longer serviced.
I've been told that the machine needs to be retrofitted so, has anyone used Linuxcnc on one of these lathes?
If it's been posted I couldn't find it so sorry about that.
All help appreciated.
- Thank you received: 4652
19 Apr 2016 09:18 #73584
Replied by andypugh on topic Mazak M4 Lathe
One was done quite a while ago:
forum.linuxcnc.org/forum/30-cnc-machines/3734-my-m4-mazak-lathe
Bear in mind that that was 2001, and there have been significant developments in software and hardware since then.
For example it makes very little sense to use a 5i20 on any new conversion.
Time to create page: 0.165 seconds
