3D tube bender
10 years 5 months ago #75180 by ronaldinho07
3D tube bender was created by ronaldinho07
Just found this video,really interested in.I wonder how did they control it,looks like 6 axis hexapod + 1 axis for tube feeder.Can linuxcnc control this machine :huh:
10 years 5 months ago #75187 by andypugh
Replied by andypugh on topic 3D tube bender
It looks like an excessively-complicated version of:
And I suspect that the Nissin can do tighter bends, as there isn't a hexapod in the way.
However, I see no reason why LinuxCNC couldn't control either style.
10 years 5 months ago - 10 years 5 months ago #75212 by ronaldinho07
Replied by ronaldinho07 on topic 3D tube bender
Anyway ,i am going to upgrade my NC tube bender,it uses old hydraulic stuff for bending.
I will add 2 servo motors for feeding the tube and turning it when making 3D bending.And 1 servo motor(about 3kw) for making bend angle.
At first i am going to use Mach 3,because mach3 have a teach-mode,so that i can "manually program"->mach3 will remember and using this manual Gcode for automatic operation.
But as far as i know,mach 3 can remember location(gcode) for only 3 axis in teach mode.Is there any equivalent method of teaching in linuxcnc ,with more than 3 axis teaching?
Thank you !
Last edit: 10 years 5 months ago by ronaldinho07.
10 years 5 months ago #75214 by andypugh
The following user(s) said Thank You: ronaldinho07
10 years 5 months ago #75217 by ronaldinho07
andypugh wrote: Have a look here: forum.linuxcnc.org/forum/21-axis/30986-a...osition-logger#74810
great,thank Andy
Time to create page: 0.309 seconds
