5i25 + 7i74 + 7i71 communication errors
- terkaa
- Thank you received: 3
10 Jun 2016 12:23 - 10 Jun 2016 12:24 #75760
by terkaa
5i25 + 7i74 + 7i71 communication errors was created by terkaa
Last edit: 10 Jun 2016 12:24 by terkaa.
- Thank you received: 5321
10 Jun 2016 13:15 - 10 Jun 2016 13:15 #75763
Replied by PCW on topic 5i25 + 7i74 + 7i71 communication errors
There were some sserial error handling bugs introduced in LinuxCNC 2.70 to 2.7.3 I would suggest first up grading to 2.7.4 if you have not already done so
In addition, the most common issue is noise introduced in the parallel cable, not the CAT5 so watch the routing of these cables
and keep them away from noise sources as much as possible
Last edit: 10 Jun 2016 13:15 by PCW.
- Thank you received: 4652
10 Jun 2016 13:23 #75765
Replied by andypugh on topic 5i25 + 7i74 + 7i71 communication errors
Is it stopping the serial port?
There was an update to both LinuxCNC and the smart-serial firmware a few months ago to make the system more robust to sserial errors.
- terkaa
10 Jun 2016 13:33 #75766
by terkaa
Replied by terkaa on topic 5i25 + 7i74 + 7i71 communication errors
Parallel cables are shielded and 3 feet long. Those are not routed near any other wires.... So I do not think that is issue here. Version is 2.7.4.
10 Jun 2016 13:36 #75767
I think I was auto-corrected. I meant to ask if the smart-serial port was being stopped.
Smart-serial errors suggest noise in the CAT5 cables. Are they shielded?
Parallel cables are shielded and 3 feet long..
10 Jun 2016 13:45 #75769
what actual errors are you getting?
- terkaa
10 Jun 2016 13:55 - 10 Jun 2016 13:57 #75770
by terkaa
PCW : I did not have time to "dig into it" today. But it was communication error(13) and always with 7i71 not any other cards. Andy yes all cables are CAT5 shielded ones. And short ones either 2 or 3 feet long. And routed with 24VDC input wires (AC110V switched ones run on other side of electric cabinet). I have to restart LinuxCNC to get things running again. Also should I connect PE to screw terminal near RJ45 jacks on 7i74 card?
Tero
Tero
Last edit: 10 Jun 2016 13:57 by terkaa.
- terkaa
10 Jun 2016 14:02 - 10 Jun 2016 14:06 #75771
by terkaa
Card is driving these relays:
eu.mouser.com/ProductDetail/Schneider-El...odqPAciXLL5D0Q%3d%3d
Do these need flyback diodes?
Last edit: 10 Jun 2016 14:06 by terkaa.
10 Jun 2016 14:08 #75772
Probably, the data sheet says:
"Coil interference suppression - Without"
10 Jun 2016 14:11 - 10 Jun 2016 14:13 #75773
If this is a noise problem its much more likely to be getting into the parallel cables than the CAT5 cables
since the signals are single ended in the parallel cable, but with the fixes in 2.7.4 a few random impulse
noise errors should not cause any trouble.
Need the actual error to figure out whats going on (communication errors are generic, the other errors give the specific cause)
one type of error that would require a restart (well really just a stop/start of sserial) would be a 7I71 remote fault
Last edit: 10 Jun 2016 14:13 by PCW.
Time to create page: 0.390 seconds
