Starting big, making a SLS with Linux CNC
21 Aug 2016 22:03 #79214
Indeed not. And I suspect that your machine might end up being further than most from what the setup tools expect to be configuring for.
That's handy, I have a slicer for Inventor
Will the machine be servo or stepper?
Will the laser follow a fixed raster with modulated laser power, or follow a 3D-printer style path with the laser on all the time?
Replied by andypugh on topic Starting big, making a SLS with Linux CNC
You mention that LinuxCNC can handle 9 degrees of movement, but the setup tool only provides for 4. I'm guessing you can't rely on the setup tool for everything.
I can produce a detailed object in Inventor ready to be given to a fabrication technician.
- wyattwic
21 Aug 2016 22:48 #79216
by wyattwic
Replied by wyattwic on topic Starting big, making a SLS with Linux CNC
I already have a full set of bipolar steppers, and I have the parts on hand to solder together the matching drivers.
In regards to the print path I may do the same as a 3d printer, since SLS is a similar technology.
Would you be willing to share that slicer?
- wyattwic
21 Aug 2016 23:00 #79217
by wyattwic
I feel like an idiot. Apparently Inventor now has "send to 3D printer". Can LinuxCNC work well with STL files or am I still gonna need a slicer?
21 Aug 2016 23:09 #79218
Yes, there is a link in the video comments. www.bodgesoc.org/slicer1.3.ivb
21 Aug 2016 23:22 #79219
You probably still need a slicer. But if you are going to use 3D-printer paths rather than a raster then there are lots of slicers out there that create LinuxCNC-compatible G-code. See for example slic3r.org
My slicer for Inventor does _not_ create G-code, it was written specifically to avoid the STL stage that creates facets on the model and was for the use of the chap who built that DPL printer that I linked to earlier.
The following user(s) said Thank You: wyattwic
- Thank you received: 7490
21 Aug 2016 23:26 #79220
Replied by tommylight on topic Starting big, making a SLS with Linux CNC
<=== still here reading and waiting to ...... pounce !
Am working on making Linuxcnc control some machines i make, and it was quite a long journey, but finally tonight i have some really nice results. Here is the link to the original post, if interested (Andy i know you are !!
forum.linuxcnc.org/forum/10-advanced-con...e-superimosing-a-pic
- wyattwic
22 Aug 2016 03:40 #79232
by wyattwic
Hey guys, thanks for the very helpful information! I have been chatting with some of my other friends and they have given me additional design ideas.
If y'all don't mind, Ill post my build progress here, on top of all my CADs/notes for building it. Why build something awesome if others cant enjoy it too.
- wyattwic
22 Aug 2016 04:38 #79233
by wyattwic
Holy crap guys. I just got a call from a very very drunk friend. He's a material scientist.
This is just an idea but I would love to have your opinions. While I know LinuxCNC probably doesn't support it, I think it could be integrated using alternative means.
This dude just thought of a way to do multicolor plolycarbonate in SLS. His suggestion was to have a injet printer pass over the bed between every layer to deposit standard ink where the laser is due to hit. The SLS process causes the polycarbonate particulate to melt and fuse with the ink.
Being a printer tech, I know that the inkjet would have to pass within 0.003in of the bed. How would I prevent it from kicking up dust and clogging the heads? Maybe a large static charge?
Just food for thought. Ill research it later but I wanted to put that out there since I am somewhat impaired myself.
22 Aug 2016 09:28 #79240
(FWIW, I am a Materials Scientist by training too)
[/quote]Being a printer tech, I know that the inkjet would have to pass within 0.003in of the bed. How would I prevent it from kicking up dust and clogging the heads?/quote]
Maybe you just need a bigger gap? There are industrial printing systems that throw the ink further.
Does the levelling roller consolidate the powder at all?
Much more useful than those immaterial scientists.Holy crap guys. I just got a call from a very very drunk friend. He's a material scientist.
- wyattwic
22 Aug 2016 13:19 #79248
by wyattwic
There are industrial inkjets, but the largest gap I know of is about 0.01in. Keep in mind that's a $2k+ printer. I'm cheap
I should be able to bring the printer up somewhat, but as it gets higher it becomes less accurate and skewed in the direction of travel. Then again, when at the proper distance a home inkjet nozzle can be about 12 microns off. If I were to move from 0.003 to 0.01 or 0.1 I should be looking at inaccuracies of no more than 40 microns or 400 microns respectively.
I'm not 100% on what you mean by consolidate. I assume your talking about somewhat packing the powder down? If so, I would have to say somewhat, but I don't know how much for sure. I could possibly do a double pass on the roller to pack it down more.
Again its food for thought. A stretch goal. In order to pull this off I would need to find a way to slice the model into color layers and print it over the bed using the existing driver with some positioning modifications.
Well, I am off to work. When I get back I am going to retouch on my CADs for the whole rig. Once I think its a final draft ill post it up here.
Time to create page: 0.131 seconds
