MESA 5i25 & 7i77 + 6i25 & 7i76 com error
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Sep 2016 17:47 - 14 Sep 2016 17:48 #80452 by bkt
Sorry at all ... but in this case I not understand these:
For N = 0 ... [KINS](JOINTS -1)
Ini File Item hal pin name
[JOINT_N]BACKLASH ini.N.backlash
[JOINT_N]FERROR ini.N.ferror
[JOINT_N]MIN_FERROR ini.N.min_ferror
[JOINT_N]MIN_LIMIT ini.N.min_limit
[JOINT_N]MAX_LIMIT ini.N.max_limit
[JOINT_N]MAX_VELOCITY ini.N.max_velocity
[JOINT_N]MAX_ACCELERATION ini.N.max_acceleration
[JOINT_N]HOME ini.N.home
[JOINT_N]HOME_OFFSET ini.N.home_offset
For L = x y z a b c u v w:
[AXIS_L]MIN_LIMIT ini.L.min_limit
[AXIS_L]MAX_LIMIT ini.L.max_limit
[AXIS_L]MAX_VELOCITY ini.L.max_velocity
[AXIS_L]MAX_ACCELERATION ini.L.max_acceleration
there is hal pin for modify "on fly" (on customcomp or gcode for example) the machine parameter?? or is the new grammar to write correctly hal file?
Regards
giorgio
Last edit: 14 Sep 2016 17:48 by bkt.
15 Sep 2016 01:03 #80462 by Todd Zuercher
Replied by Todd Zuercher on topic MESA 5i25 & 7i77 + 6i25 & 7i76 com error
Not being intimately familiar with Master or JA. Where did that bit of code come from (what file...)
  • bkt
  • Platinum Member
  • Platinum Member
15 Sep 2016 10:05 #80467 by bkt
came from these man for INI file .....
these the link ...
_consistent_joints_axes_specifications
Regards
Giorgio
15 Sep 2016 12:42 #80470 by Todd Zuercher
In that case since you are already using JA you probably already have that taken care of. If you would like you could post your ini and hal files (only need to see your hal file(s) with the joint and axis refrences) and we could have a look and offer an opinion if we think any modifications are necessary. (but I doubt any will be needed)
The following user(s) said Thank You: bkt
  • bkt
  • Platinum Member
  • Platinum Member
16 Sep 2016 12:32 #80494 by bkt
This night I study the doc linked by me .... I need 20 row modification on hal file ... and I think all work ok ...
So next week I try the update ...
If these solve the issue I update the post.
Regards
Giorgio
Time to create page: 0.079 seconds
