latency-histogram gets error messages
02 Oct 2016 17:41 #81158 by skelem
When I run latency-histogram, I get hundreds of these messages on the console:
msg=can't use non-numeric floating-point value as operand of "*"
Any idea what is causing this or how to track it down? I couldn't find that error message is not in any of the files in the linuxcnc source tree.
02 Oct 2016 19:02 - 02 Oct 2016 19:04 #81160 by dgarrett
Replied by dgarrett on topic latency-histogram gets error messages
the only place i see for this would occur for an
invalid (non-positive) variance calculation which
might be due to something abormal with the system
configuration.
What version of LinuxCNC and how installed?
What is result of the following shell commands?
uname -a
and
lsb_release -a
Or just post the file created by this command:
linuxcnc_info
Last edit: 02 Oct 2016 19:04 by dgarrett.
05 Oct 2016 10:46 #81254 by skelem
Replied by skelem on topic latency-histogram gets error messages
% linuxcnc_info
This file can be posted to a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
VIEWER=gedit
Date: Wed Oct 5 08:43:58 PDT 2016
UTC Date: Wed Oct 5 15:43:58 UTC 2016
this program: /local/home/skelem/cad/linuxcnc/scripts/linuxcnc_info
uptime: 08:43:58 up 22:54, 2 users, load average: 0.17, 0.14, 0.16
lsb_release -sa: Ubuntu Ubuntu 16.04.1 LTS 16.04 xenial
which linuxcnc: /local/home/skelem/cad/linuxcnc/scripts/linuxcnc
pwd: /local/home/skelem
USER: skelem
LOGNAME: skelem
HOME: /local/home/skelem
EDITOR: emacsclient
VISUAL:
LANGUAGE:
TERM: xterm-256color
COLORTERM:
DISPLAY: localhost:10.0
display size: 1920x1080 pixels (508x286 millimeters)
uname items:
nodename -n: green76
kernel-name -s: Linux
kernel-vers -v: #2 SMP PREEMPT Sat Oct 1 21:56:09 PDT 2016
machine -k: green76
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.4.21-rt31 root=UUID=ecaf0aba-b53c-4497-8926-183c83cacdb8 ro quiet splash vt.handoff=7
model name: Intel(R) Core(TM) i7-5557U CPU @ 3.10GHz
cores: 2
cpu MHz: 3100.000
parport:
serial:
Versions:
gcc: gcc (Ubuntu 5.4.0-6ubuntu1~16.04.2) 5.4.0 20160609
python: Python 2.7.12
git: git version 2.7.4
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0~pre1
REALTIME: /local/home/skelem/cad/linuxcnc/scripts/realtime
RTS: uspace
HALLIB_DIR: /local/home/skelem/cad/linuxcnc/lib/hallib
(gedit:14709): dconf-WARNING **: failed to commit changes to dconf: Could not connect: Connection refused
05 Oct 2016 10:54 #81255 by skelem
I added glade:
glade: glade 3.18.3
I added several glade gtk packages, but, apparently, not the one that linuxcnc_info is looking for.
05 Oct 2016 11:39 - 05 Oct 2016 11:40 #81258 by dgarrett
So -- a recent(!) RIP on ubuntu 16 xenial with preempt-rt and x84
0) Did you build the prempt-rt kernel?
1) What 'Max Jitter' result do you get with
latency-test
2) try a minor edit to
/local/home/skelem/cad/linuxcnc/scripts/latency-histogram
to see what is being reported for variance:
-    puts msg=$msg
+    puts "msg=$msg variance=$variance"
and post the exact error message msg=?
3) it might be instructive to see all of hal while running latency-histogram. To do this, start latency-histogram:
$ source /local/home/skelem/cad/linuxcnc/scripts/rip-environment
$ latency-histogram &
then in a separate terminal,
$ halcmd show >| /tmp/l.show
and post the file /tmp/l.show
not an issue for latency-histogram -- doesn't use any gtk or glade
Last edit: 05 Oct 2016 11:40 by dgarrett.
05 Oct 2016 13:20 - 05 Oct 2016 13:34 #81265 by skelem
(0) Did you build the prempt-rt kernel?
I thought so. I downloaded the kernel source, applied the corresponding rt patches, used xconfig to enable PREEMPT, built and installed it. The correct name shows up in uname -r.
% grep PREEMPT rt/linux-4.4.21/.config
CONFIG_PREEMPT_RCU=y
CONFIG_PREEMPT_NOTIFIERS=y
CONFIG_PREEMPT=y
CONFIG_HAVE_PREEMPT_LAZY=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT__LL=y
# CONFIG_PREEMPT_RTB is not set
# CONFIG_PREEMPT_RT_FULL is not set
CONFIG_PREEMPT_COUNT=y
# CONFIG_DEBUG_PREEMPT is not set
# CONFIG_PREEMPT_TRACER is not set
(1) Max Jitter
16017587 servo thread (1ms)
16866119 base thread (25us)
(2)
Note: Using POSIX non-realtime
msg=can't use non-numeric floating-point value as operand of "*" variance=-1722378192
msg=can't use non-numeric floating-point value as operand of "*" variance=-1861254779
msg=can't use non-numeric floating-point value as operand of "*" variance=-1624845419
msg=can't use non-numeric floating-point value as operand of "*" variance=-1671011147
msg=can't use non-numeric floating-point value as operand of "*" variance=-768294139
msg=can't use non-numeric floating-point value as operand of "*" variance=-1028587226
Last edit: 05 Oct 2016 13:34 by skelem. Reason: grammar correction
05 Oct 2016 13:57 #81267 by PCW
Replied by PCW on topic latency-histogram gets error messages
Yow! 16 ms is not good. I suspect you built a non-realtime kernel:
If you use xconfig, the preemption options are in the processor types and features section
and you need to select the "fully preemptable kernel" option
05 Oct 2016 14:16 #81269 by dgarrett
not good.
This indicates something wrong as well:
1) did you ./configure --with-realtime=uspace ?
2) did you make setuid ?
I wonder if there are items not tagged with
CONFIG_PREEMPT that are important for the kernel
build. You may need to find a working preempt-rt
kernel config file for your kernel version.
I notice on my (older, debian jessie) working uspace
config has items not listed as set in your grep output:
CONFIG_PREEMPT_RT_BASE=y
CONFIG_PREEMPT_LAZY=y
CONFIG_PREEMPT_RT_FULL=y
CONFIG_DEBUG_PREEMPT=y
and some that are not set (where you have it set):
# CONFIG_PREEMPT__LL is not set
Ref:
$ grep PREEMPT /boot/config-4.1.0-0.bpo.2-rt-amd64
CONFIG_PREEMPT=y
05 Oct 2016 19:28 #81286 by skelem
Can you post your config file?
Thanks,
Steve
05 Oct 2016 20:02 #81287 by dgarrett
added .txt suffix for forum acceptance
The following user(s) said Thank You: skelem
