- Thank you received: 5334
latency-histogram gets error messages
10 years 3 weeks ago #81267
Replied by PCW on topic latency-histogram gets error messages
Yow! 16 ms is not good. I suspect you built a non-realtime kernel:
# CONFIG_PREEMPT_RT_FULL is not set
If you use xconfig, the preemption options are in the processor types and features section
and you need to select the "fully preemptable kernel" option
- dgarrett
- Thank you received: 297
10 years 3 weeks ago #81269
by dgarrett
This indicates something wrong as well:
1) did you ./configure --with-realtime=uspace ?
2) did you make setuid ?
I wonder if there are items not tagged with
CONFIG_PREEMPT that are important for the kernel
build. You may need to find a working preempt-rt
kernel config file for your kernel version.
I notice on my (older, debian jessie) working uspace
config has items not listed as set in your grep output:
CONFIG_PREEMPT_RT_BASE=y
CONFIG_PREEMPT_LAZY=y
CONFIG_PREEMPT_RT_FULL=y
CONFIG_DEBUG_PREEMPT=y
and some that are not set (where you have it set):
# CONFIG_PREEMPT__LL is not set
Ref:
Replied by dgarrett on topic latency-histogram gets error messages
not good.16017587 servo thread (1ms)
Note: Using POSIX non-realtime
Ref:
$ grep PREEMPT /boot/config-4.1.0-0.bpo.2-rt-amd64
CONFIG_PREEMPT_RCU=y
CONFIG_PREEMPT_NOTIFIERS=y
CONFIG_PREEMPT=y
CONFIG_HAVE_PREEMPT_LAZY=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT_RTB is not set
CONFIG_PREEMPT_COUNT=y
# CONFIG_PREEMPT_TRACER is not set
- skelem
10 years 3 weeks ago #81286
by skelem
Replied by skelem on topic latency-histogram gets error messages
Can you post your config file?
Thanks,
Steve
Thanks,
Steve
- dgarrett
10 years 3 weeks ago #81287
by dgarrett
added .txt suffix for forum acceptance
The following user(s) said Thank You: skelem
- skelem
10 years 3 weeks ago #81367
by skelem
I re-built and get the following for jitter:
7,825,205 servo thread (1ms)
7,931,188 base thread (25us)
which is about 1/2 of what it was before.
I checked for PREEMPT in .config:
CONFIG_PREEMPT=y
# CONFIG_DEBUG_PREEMPT is not set
But then I noticed that ACPI was still enabled. I wasn't able to disable ACPI using "make gconfig", either as me or as root, so I edited .config manually, and re-built...
and CONFIG_ACPI is changed back to "y" when I run "make"! WTF?
CONFIG_PREEMPT=y
10 years 3 weeks ago - 10 years 3 weeks ago #81369
8 ms is still quite terrible, there's very likely some basic setup still wrong
Do you have all power management disabled in the BIOS setup? (including all Cstates)
Here's a third gen I5 running Preempt-RT:
freeby.mesanet.com/elite8300-preempt-rt.png
(The Latency problem is not too likely to be ACPI related plus you need some ACPI functions for power down etc)
Last edit: 10 years 3 weeks ago by PCW.
Time to create page: 3.247 seconds
