Noobie Alert-questions inbound
- Ross77
21 Feb 2017 22:58 #88470
by Ross77
Noobie Alert-questions inbound was created by Ross77
Good evening, I've just signed up after lurking for a while. I'm in the process of setting up my workshop and ready to take the plunge into LinuxCNC (thanks Clive S for the advice so far).
I have no experience in Linux so I will be starting from scratch. first stupid question is can LinxCNC be used for all machine types? first priority is the mill and lathe but it would be good to have the same programme for all machines and hope to upgrade the laser and build 3d printer.
Thanks in advance
Thanks in advance
- Thank you received: 4144
22 Feb 2017 02:36 #88474
Replied by rodw on topic Noobie Alert-questions inbound
First answer then
Yes, LinuxCNC can drive all of the machines you listed.
Mill, Lathe, Laser and 3D printer.
Each configuration is generally stand alone in a separate folder under the config directory so it is possible to use one PC to drive them all.
The following user(s) said Thank You: Ross77
- cncnoob1979
- Thank you received: 75
22 Feb 2017 03:39 - 22 Feb 2017 03:40 #88478
by cncnoob1979
Replied by cncnoob1979 on topic Noobie Alert-questions inbound
I'll mention the laser
yes a laser :/
You can control anything that has +-10v analog voltage.
If it uses pwm signals and analog voltage it makes it easy.
You just have to figure out what you want and what the current controls are. Many people use linuxcnc control all sorts of machines.
Edit: Rodw beat me to the laser
Last edit: 22 Feb 2017 03:40 by cncnoob1979.
- Ross77
23 Feb 2017 20:45 #88556
by Ross77
Replied by Ross77 on topic Noobie Alert-questions inbound
Thanks for the replies. that's good to know.
So next question. Which is the best version to start with? looking to use one of the mesa Ethernet cards.
Think I need the pre-empt RT version, but some pointers would be good.
Thanks again
Thanks again
23 Feb 2017 21:33 #88558
Yes, you need the Preemptive Real time version. This means there is a different installation path. You might as well then install a more recent version of Linux. With that done, you might as well then compile LinuxCNC from source.
So I would suggest you start here with cncnoobs excellent tutorial on installing Linux Mint.
forum.linuxcnc.org/9-installing-linuxcnc...h-rip-install-or-deb
If you are running a mill, I would go with V 2.7
If you are running a gantry, you probably will want to use the joint axis homing that is only in master.
Once you have the source, it is very easy to swap between versions using git.checkout commands.
- Ross77
23 Feb 2017 22:59 #88563
by Ross77
Thanks, that looks quite daunting.....
Would I be better using the live install and practicing with the parallel port first?
So if I did go with Mint, would I need to follow post 2? is that what you meant by compiling linuxCNC at source?
- cncnoob1979
23 Feb 2017 23:11 #88564
by cncnoob1979
Yes you would want post 2.
- Ross77
23 Feb 2017 23:50 #88568
by Ross77
Thanks. I'll get Mint installed and probably be back asking more questions :0)
24 Feb 2017 08:40 #88573
With cncnoob looking over your shoulder, it will be a breeze
I only wish he had put that thread together before I tackled the install. I'm still at a loss to understand why he credits me for helping to show him the way..
We might be both cnc noobs, but he is way over the top with his knowledge of Linux than I am. The only thing in my favour is that I am old enough to remember the DOS prompt....
- Thank you received: 4652
24 Feb 2017 13:19 #88582
That's not a bad idea. It's a well-trodden path and works OK for many people.
Replied by andypugh on topic Noobie Alert-questions inbound
Time to create page: 0.181 seconds
