Spindle configuration
9 years 7 months ago #90200 by andypugh
Replied by andypugh on topic Spindle configuration
This is no longer a LinuxCNC question, and so I am only able to guess what the problem might be, and probably guess less effectively than you.
Maybe the tachometer (or command) is reversed and that causes an error at high speeds?
Is every terminal that was previously connected when it worked still connected to something?
9 years 7 months ago #90365 by Nondepietjes
Replied by Nondepietjes on topic Spindle configuration
When the spîndel goes to higher voltage the relay on X2 board is continuosly shut on and off
9 years 7 months ago #90371 by andypugh
Perhaps the power supply to the board is weak?
9 years 5 months ago #92561 by Nondepietjes
I have fund some more information about the X2 panel.
So when i try to set a voltage of 0.5V the relay K500 is switched on and of.
K500 is on the bottem left.
when K500 switched on and of the RF light is switched on and off and everything is going in pulses.
Maby somebody that understand this schedule.
Thank for having a look.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Time to create page: 0.311 seconds
