Spindle configuration
9 years 7 months ago - 9 years 7 months ago #89947 by Nondepietjes
Replied by Nondepietjes on topic Spindle configuration
Yes i think so. but the X2 panel in the document is not the same as on my machine. X1 panel is correct
Last edit: 9 years 7 months ago by Nondepietjes.
9 years 7 months ago #89948 by andypugh
Replied by andypugh on topic Spindle configuration
Any red LEDs?
9 years 7 months ago #89950 by Nondepietjes
Yes, that of the RF. Disable led.
in my hal.file my spindle-on isn't connected. to witch pin should i connect it?
File Name: MD5_IT_2017-03-20.hal
File Size:11.41 KB
File Name: MD5_IT_2017-03-20.ini
File Size:2.87 KB
9 years 7 months ago #89951 by andypugh
spindle-on in your HAL is created but not used. Just delete it.
It looks to be left over from a previous config or edit or something.
Your drive seems to have two separate enable inputs, Ready-for-operation and Controller-ready.
Try connecting one to the halui.machine.is-on HAL pin.
9 years 7 months ago - 9 years 7 months ago #89952 by Nondepietjes
Can you give some tips or an example?
So i don't have to connect extra cables? I'm searching a long time on this and i'm totaly lost ;p
9 years 7 months ago #89961 by andypugh
Nondepietjes wrote: Can you give some tips or an example?
No, I think you do need to connect extra cables, and one of the cables needs to be controlled from HAL by halui.machine.is-on (or any other pin that you want to use, like axis.0.amd-enable-out)
The following user(s) said Thank You: Nondepietjes
Time to create page: 0.332 seconds
