Linuxcnc error
9 years 6 months ago - 9 years 6 months ago #92426 by rodw
Replied by rodw on topic Linuxcnc error
It is time to start again from scratch and this journey to date as part of your learning experience.
As Arceye has said, you need to compile LinuxCNC from source. You really need to get your hands dirty and stop taking the easy way out by ignoring our advice. I would blow away my copy of Linux at this stage and reinstall it based on this step by step tutorial.
forum.linuxcnc.org/9-installing-linuxcnc...-or-deb?limitstart=0
When you compile LinuxCNC from source, make sure you install it as run in place and learn how to start linuxcnc from the command line without any menus.
So then, configure your hardware without bothering about the toolchanger. Once you have got it going, then come back to the toolchanger. There are no shortcuts, You have to do the hard yards.
By the time you get this far you should have learnt a fair bit about LinuxCNC and installing the toolchanger will be a walk in the park.
All of us have had a longer journey than we initially expected. I never wanted to install Linux and patch the OS to get the preemptive kernel, I never wanted to have to learn how to compile LinuxCNC, I did not want to learn how to change the GUI screen using Glade and I did not want to learn how to write a handler for the screen in Pythion and Also ,I never expected that I would end up writing a number of HAL components to get my machine operational. But I had to and I did it. Its been a journey over six months but I am finally there.
Someone has done all the hard work for you, there seems to be only 2 files to install and they even made a make file for you but there are no shortcuts, you have to take the journey one step at a time. At the end, you'll knock that tool changer over in a day.
Last edit: 9 years 6 months ago by rodw.
9 years 6 months ago #92479 by chelseafan
Replied by chelseafan on topic Linuxcnc error
cheers guys. i managed to follow your instructions arceye thanks and it all loaded up linuxcnc, It recognises tool 4 is loaded but the m6 command wont activate the toolchanger. the play button presses and stays pressed on the top bar but nothing happens. i tried looking through the hal pins in the machine menu and tool change pin is true. So its doing something i guess.
you are right rodw and i guess i am going to have to learn things, this machine should both run my triac and orac but i think the best thing for me to do would start again on a seperate machine for the triac which will let me get the knowledge i need. The machine does seem to be working as should now except the toolchanger which is strange.
9 years 6 months ago #92482 by chelseafan
you are right rodw and i guess i am going to have to learn things, this machine should both run my triac and orac but i think the best thing for me to do would start again on a seperate machine for the triac which will let me get the knowledge i need. The machine does seem to be working as should now except the toolchanger which is strange. i do keep getting the error EMC_TASK_PLAN_RUN:507 though
1 year 8 months ago - 1 year 8 months ago #322853 by xenon-alien
Replied by xenon-alien on topic Linuxcnc error
Hello!
I hope you don't mind, if i ask here a question about an error in LCNC.
In the config, at start up no program is loading. (OPEN_FILE = "")
I have a lathe with 3 axis. X axis has an electromagnetic brake. When disabling the drivers pops up an error "File not open" in the right bottom corner.
On the lathe there is a microswitch, to check, was the part cut off. If it pressed, pops up a message component that the cutter tool is boked.
Today, when i pressed manually the switch, the default message pops up and also the "File not open" in the right bottom corner.
The "File not open" error in the right bottom corner also pops up if i press the Run Program button. It is logical.
Not really understand, why is it happening.
Can anyone give any advice?
Update:
We just assembling the mechanics and the "File not open" error pops up again without pressing/switching anything. The spindle servo was turn on a few times. But there are EMI filters...
It looks like something pressing the "play" button (Run Program)
Update2:
The path to "on_abort.ngc" was the errorĀ
Last edit: 1 year 8 months ago by xenon-alien.
Time to create page: 0.467 seconds
