PID SERVO TUNING
- Yannis
- Thank you received: 4
11 Jul 2017 05:14 #95642
by Yannis
PID SERVO TUNING was created by Yannis
Hi
i try to tune my servo with mesa 5i25 an7i77 and mesa wizard
i try first to set the P
when i set anything bigger then 0.25 the motor oscillate like crazy(all the others values is 0)
i check almost every pid setting thread in the forum and never find so low values for the P
what is your suggestion?
- Online
- Thank you received: 5321
11 Jul 2017 13:41 #95659
Replied by PCW on topic PID SERVO TUNING
If the machine control scaling is not normalized, the P settings will depend on scaling
and metric machines with have a 25 times lower P values than inch machine so 0.25 is
possible but does seem low. Also P may be low if you don't have the encoder scaling right.
Are you drives running in velocity mode? If so, have the drives velocity loops been tuned?
If the drives are running in torque mode, the tuning procedure is quite different
(P by it self will almost always oscillate)
The following user(s) said Thank You: Yannis
- Yannis
11 Jul 2017 14:20 #95663
by Yannis
Replied by Yannis on topic PID SERVO TUNING
Hi
i have a BRU500 and BRU200ANALOG SERVO DRIVERS in a INTERMAC 1500 GLASS MACHINE
the machine is gantry machine with 2 motors on y and c axis
the c axis motor is mountaid to planetary gear box and i tune it (i think) and i was abble to reach 17m/min
P 1.36 FF1 0.00385
the other motors are different
if i try P values> 0.5 they oscilate like crazy
the previus controller was OSAI10
is it possible the c axis motor to be in velocity mode and the others(x,y,y,z) to be on torque mode?
P 1.36 FF1 0.00385
- Thank you received: 1472
11 Jul 2017 16:00 #95675
Replied by Todd Zuercher on topic PID SERVO TUNING
Could you post your config files (ini & hal)? It is possible that configuration errors could be contributing to your instability.
It is possible, but I would be surprised if they were.
- Yannis
11 Jul 2017 18:21 #95681
by Yannis
hi right now i try to solve another problem
i try to upgrade the old pc with a hp xw 4400 workstation and i think that the pc can not see the 5i25 mesa card
when i do that i will post the files
PCW here is the error message
- Yannis
11 Jul 2017 18:27 #95683
by Yannis
- Online
11 Jul 2017 19:03 #95684
The error message indicates that the 5I25 does not have communication with the 7I77
Most likely causes are power (5V power in this case) and cabling
- Yannis
12 Jul 2017 14:51 #95734
by Yannis
Hi
this is the hal an the ini file
i use the pnccon wizard
all the values are default of the pnccon wizard
waiting for suggestions
\thanks
\thanks
12 Jul 2017 14:57 #95735
I think those are the wrong configuration files. They are for a parallel port step-motor configuration generated by Stepconfig, not a servo configuration by PNCconfig.
- Yannis
12 Jul 2017 20:09 #95739
by Yannis
sorry i will post the right one tomorrow morning local time
the behavior of the motor is very strange it oscillate with P value near to zero
i hope that to be the result of default values of the PNCconfig
Time to create page: 0.157 seconds
