PID SERVO TUNING
- Thank you received: 1472
12 Jul 2017 20:12 #95740
Replied by Todd Zuercher on topic PID SERVO TUNING
I suspect it might be. Pncconf has had some default settings that do not work with mm configured machines. (At least in the resent past, don't know if they've been corrected.)
- Yannis
- Thank you received: 4
13 Jul 2017 07:49 #95749
by Yannis
Replied by Yannis on topic PID SERVO TUNING
- Yannis
13 Jul 2017 07:50 #95750
by Yannis
Hi
the correct files
the correct files
- Thank you received: 5321
13 Jul 2017 15:51 #95759
Replied by PCW on topic PID SERVO TUNING
At the minimum you should change all the OUTPUT_SCALE numbers to 10
If you change the PID values to 0 do you still get oscillations?
Can you post a halscope plot of the oscillations here?
- Yannis
13 Jul 2017 17:05 #95762
by Yannis
Yes i have oscillation even with 0 P with OUTPUT_SCALE numbers to 10
- Yannis
13 Jul 2017 17:11 #95763
by Yannis
i can not load halscope .log because it is not recognized the extension log
13 Jul 2017 17:44 #95765
A HALScope screenshot would probably be better than a log
If the drives oscillate with 0 PID terms that suggests a problem with the drive analog
input wiring or the drive tuning itself
- Yannis
13 Jul 2017 18:26 #95767
by Yannis
it is something common to control in the same machine some motors in velocity mode and some in torque mode??
- Yannis
13 Jul 2017 18:33 #95768
by Yannis
the motor when i enable it with F2 oscillate until the joint go to an error
13 Jul 2017 18:44 - 13 Jul 2017 18:44 #95769
Right so that tends to indicate a drive or wiring issue
If you just enable the drive with the analog inputs disconnected, does it still oscillate?
Last edit: 13 Jul 2017 18:44 by PCW.
Time to create page: 0.175 seconds
