Errors preventing LinuxCNC from starting.
9 years 3 weeks ago #100147 by cintsa cnc
I meant to say the address on the computer running Linux CNC, not the CNC machine
9 years 3 weeks ago #100151 by andypugh
192.168.1.121 is the default IP of the Meas Ethernet cards. Are you sure you are looking in the right place? (And what are you actually looking for?)
9 years 3 weeks ago #100153 by PCW
192.168.10.101/24 is the host computers IP address range for connection to you local network,
probably assigned via DHCP.
The FPGA card cannot share this range and must have an independent connection and IP address range. That is, you cannot share the real time LinuxCNC Ethernet connection with general internet connections so if you want internet connectivity you must have 2 network interfaces on the host.
This can be done in a variety of ways. Some Motherboards have 2 Ethernet connections, an additional PCI/PCIE Ethernet card can be installed, a USB-->Ethernet dongle, a USB-WIFI adapter etc etc.
Once this is done you need to setup one network interface for internet access (this should normally be the USB/external card) and the other (usually motherboard) interface for connecting to the FPGA card
I would suggest using the FPGA cards 10.10.10.10 address rather than 192.168.1.121 as its less likely to overlap with common DHCP assigned NAT address ranges
There is a bit of information about manual network setup in the hm2_eth manual page. Note that this is not really linuxCNC related but just standard Linux network setup, I typically just set up the interfaces with the network manager GUI
9 years 3 weeks ago #100154 by andypugh
PCW wrote: I typically just set up the interfaces with the network manager GUI
I don't think that you get one of those with Debian.
9 years 3 weeks ago #100155 by PCW
I think its on all Debian derivatives (its certainly on Wheezy)
9 years 3 weeks ago #100159 by andypugh
Intere4sting, it is on my Stretch PC too. I am pretty sure it is absent from my actual machine PCs.
Time to create page: 0.095 seconds
