Errors preventing LinuxCNC from starting.
9 years 2 weeks ago - 9 years 2 weeks ago #100522 by PCW
can you try just
ifconfig
Or if that doesnt work, try
ip a
Last edit: 9 years 2 weeks ago by PCW.
9 years 2 weeks ago #100524 by cintsa cnc
alwyn@debian:~$ ifconfig
bash: ifconfig: command not found
alwyn@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 1c:1b:0d:8e:36:25 brd ff:ff:ff:ff:ff:ff
alwyn@debian:~$
9 years 2 weeks ago #100525 by PCW
Looks like you do not have enp1s0 configured for a static ip address of 10.10.10.1 and it also appears unconnected
9 years 1 week ago #100560 by cintsa cnc
I am not very conversant with code so it would be greatly appreciated if you could supply the code necessary to connect the Ethernet. I would really like to get this system up and running as soon as possible.
9 years 1 week ago #100561 by PCW
This is a network setup issue, not really coding
I would suggest reading through:
wiki.debian.org/NetworkConfiguration
9 years 4 days ago #100934 by cintsa cnc
I have finally got Linux CNC configured to the MESA 7176E card and it it up and running.
There are however two other issues creating problems.
1). When I try use "gedit" nothing happens although it is listed in the ini. file. This tells me the app. was not iclude in the downloaded package, or need to be activated somehow.
If it was not included, is it possible to download it on a machine that has internet access and then transfer it to the Debian machine via USB.
The other question relates to "Axis". When I load the machine file created by using the config wizard, I get the followig error.
Error in -/.Axisrc
traceback (most recent call last)
File "/usr/bin/axis line 3513 in <module> execfile (rcfile)
File "/home/alwyn/.axis rc "line 3 in <module>
fullsize + maxgeo.split(' ')[03+'x' + maxgeo.split(' ')[1]
attributeError:('tuple' object has no attribute 'split'
There may be one or tw typo's in the above, but what does it relate to.
I am hoping you may be able to offer assistance in order to put this whole saga to rest.
Time to create page: 0.193 seconds
