Errors preventing LinuxCNC from starting.
9 years 2 weeks ago #100482 by cintsa cnc
Thank you for your support. I have found the GUi and entered the address mentioned, 10.10.10.10 but it also requires a net mask and gateway. how do i determine these?
9 years 2 weeks ago #100483 by cintsa cnc
I have also moved the jumper on the board to enable EEPROM in the hope that works but no luck so far.
9 years 2 weeks ago #100484 by PCW
You do not set the host address to 10.10.10.10 (that's the address of the FPGA card)
I would set the host address to 10.10.10.1 and netmask to 255.255.255.0
the gateway can remain blank
9 years 2 weeks ago #100489 by cintsa cnc
I have done the changes but now notice on startup of Linux i get a message that is too fast to read but failed is in RED and and it says something about failed to start network.
9 years 2 weeks ago - 9 years 2 weeks ago #100490 by PCW
Before even trying to start LinucCNC you should verify that you can ping the FPGA card
Can you post the results of these commands:
/sbin/ifconfig
uname -a
ping 10.10.10.10
Last edit: 9 years 2 weeks ago by PCW.
9 years 2 weeks ago #100521 by cintsa cnc
Attached is a PDF attachment listing the results as per your rquest
Time to create page: 0.163 seconds
